Question about RCA Rv-9970a Pro Logic A/v Receiver
I need a manual to connect a receiver to tv
Do not know where to connect
How do i connect to a net work i know?
if you are talking about wifi network tat comes in your laptop then,
you just need to click on that wifi network, it will prompt to ask enter wifi password, then enter password and click on connect button to connect on this WiFi network.
if you don't know the password of that WiFi, then you can not connect to this.
Aug 26, 2015 | Computers & Internet
My mobile phone connects to belkin.ecO.guest so why cant I get on the internet
When you want to connect to the internet, and secure, make sure you have your own WiFi router. Then setup the connections with WPA2 and connect with that know connection. All other connections, even when they are called Guest, won't be secure and you never know if you have connection to the net or just a computer from someone close to your house.
Jan 30, 2015 | Computers & Internet
Can I get Chromecast to play thru my surround sound?
If your receiver has an HDMI input that you are connected to from an HDMI output of your TV; then yes you can listen to it in surround sound.
The HDMI input that you are using on your receiver must be designated as a TV input if it has the capability of being "assignable" in your receiver setup options; or otherwise just connected via HDMI on the rear or front panel of the chassis on TV inputs section.
Once the proper connections are confirmed, select your receiver input to TV. The TV output mode must be set to HDMI; or you will not get any sound or picture if that is the only connection. You'll have to refer to the receiver manual on how to do this if the output mode does not select automatically as I do not know what gear you are using.
If you have your speaker setup in a 5.0 or 5.1 setup; depending on the decoding capabilities of your receiver; you should be able to get audio through each channel in a variety of ways. Refer to your receiver manual for the decoding format compatibility. The decoding may also be performed by your TV as well.
Dec 08, 2014 | Denon Audio Players & Recorders
I have a Yamaha RX-V340RDS amplifier and need to know how to connect my tv, dvd recorder and hd-pvr
manual found here: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RXV340.pdf
Mar 23, 2014 | Pioneer VSX-D608 Receiver
How to sent friend request without knowing their email id
Having to know the email address of the friend you want to connect with is a setting that your friend has enabled on Linkedin.
Your friend probably enabled this setting to keep people they do not know from sending requests to connect. By having to know their email address ensures that your friend will only be able to receive requests from people they actually know or actually know their email address.
If you want to send a request and do not know the email, you will need to contact your friend by some other method to get their email address or have them send you and invite to connect. It is not possible to connect with people in any other way if they have enabled this feature.
Jan 13, 2012 | linkedin.com
How do I know what 'connection' system i need to
SSID is the name of the wireless connection that you are connected or trying to connect to. And you need to have wireless internet for the Wii to connect. Which is in the options under internet.
Sep 25, 2011 | Nintendo Wii Black Console
I dont know how to connect it to my tv!?!?!?!
Look in the manual.
http://www.retrevo.com/support/Onkyo-HT-R500-Receivers-manual/id/365bh147/t/2/
The only vital connection is a simple composite cable or whatever your unidentified TV requires. The TV has a manual, too, somewhere.
I personally would not bother routing any video from external sources through the receiver as no signal will benefit from the extra cables and connections.
Aug 13, 2011 | Onkyo HTR500 Receiver
How to hook up a telephone. I need to know how to hook up a telephone from the box outside to the phone jack inside.
In order to do that you need to know on which pair does your phone jack inside your home is connected. In case you don't know or it is not connected then you need drop wire and punching tool to connect. Simply ask your service provider on which pair he has connected connect the drop wire on the same pair and extend it to your phone jack with drop wire.
Jun 30, 2011 | Lands Phones
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: http://www.dishnetwork.com/supportsection/manuals . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Televison & Video
RCA Rv-9970a Pro Logic A/v Receiver Logo
27 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
