Question about Kitchen Ranges
Frigidaire oven model CFEF372CB2 made a popping sound started to beep and now displays the fault code F1. Turning the power of and then on has cleared the beeping but the code remains and the oven doe
Cycling the power off and then on has stopped the beeping but the fault code F1 remains and the oven does not work?
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
My oven was set to self clean. It got extremely hot and the it began beeping and flashing F1. I turned the circuit off, because I wasn't sure if it meant "Fire". So is it ok to turn the circuit...
Frigidaire's slide-in ovens feature an electronic oven controller, which serves to monitor and diagnose most electrical problems within the oven. If any of the oven's electrical systems fail, the controller will prevent the oven from functioning and will display a flashing "F" code on the oven's digital display and produce a beeping sound. To stop the beeping and clear the display, press the "STOP/CLEAR" button on the oven's control panel. Many times, the problem can be remedied by simply resetting the oven's controls. First, turn all of the oven's control knobs to the "Off" position, then allow the oven to cool to room temperature. If, after turning the oven on again, the "F" code still displays on the digital display, contact Frigidaire, as the wiring is likely to be defective.
Dec 06, 2010 | Frigidaire FEF352 Electric Kitchen Range
Washer flashes f 1 and will not start
The range/stove fault code page....
My Range is flashing a "F" something.....what does this mean??
Some terms used on this page...ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction. Oven temperature sensor - What a common sensor or temp sensor looks like.
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic by Make and or problem...hope you find this helpful :-)
A tip for the famous F1 fault code entr_anm.gif The biggest Fault Codes list that I am aware of! What does an oven temp sensor look like?Some info and tips on oven temp sensors
Newer 4 digit fault codes - Maytag, JennAir, Magic Chef Newer Frigidaire fault codes new25.gif Some newer GE built in oven fault codes are here. Newest Hamilton built GE clock fault codes are here. I have some of my own hand written fault codes, here and some more here. The Maytag Gemini range fault codes are on this page. The Maytag Accellis range codes are on this page. traffic_record.php?lc=024041009290002517 A tip:The supplier recently reversed the display areas for the clocks. Therefore you may find an F1-E0 code or E0-F1 code depending on the model. They both mean the same thing, and depending on the model determines the code reference, and location of the F code. Different manufacturer of the clocks caused this.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Cannot remove bottom oven element from wires
Most elements are mounted to the back of the baking chamber from the outside and held in place with brackets that are screwed in place. Turn the BREAKER off, & after taking the back off you should find the wires are wire nutted together.
Jul 08, 2009 | Frigidaire FEB27T5D Electric Double Oven
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
Oct 02, 2008 | Frigidaire Kitchen Ranges
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
