Question about Febi 1997 - 2003 Acura CL Transfer Case Fluid W0133-1930425 Acura Au
Car won't move when transmission gets hot.
When the car is cool it moves ,but when it get hot it stop
I have a 2003 Honda Civic hybrid. For some reason while driving and the engine temp goes half ways the car seems like it won’t go into gear. For example when I stop at a stop sign the car won’t catch gear...
Your transmission might have a broken ban . This ring or spacer is between every gear when they go the gears don't line up. Check your trans mission fluid and make sure to use the proper fluid for your make. If the transmission is going it usually starts shifting into gear hard.. It will be jerky then eventually have a problem with one gear which will lead to all gears .
May 02, 2018 | Honda Cars & Trucks
Transmission will not move car in drive after driving 20 or 30 miles . Will go in reverse and move. Will go OK if you sit for 1hr or more.
Shift solenoid is gittn hot from wear. To much resistenc. Has to cool down. Chec fluid level and cooling first. If no remedy, then replace solenoid
Apr 10, 2015 | Cars & Trucks
What would cause the mower to slow down and stop after 3 hrs mowing then after it cools down it moves what would cause it to do that ?
you have unseated valves the hotter it gets the less power you have until it stops to cool down need to take to shop and get vavle job about 100.00 dollars if you wait you will damage motor
Aug 29, 2014 | Husqvarna Garden
What happen to my car only drives on reverse but can not drive forward even you change it to Drive?
Yr auto transmission seems to be the problem. There are numerous rubber seals inside the system and may have worn off. It will usually happen when the ATF oil is hot. Stop the engine, let it cool off for about 20-30 minutes and the car will move forward in D mode. This will allow you to drive to the nearest mechanic shop. If you stop in between and put from D to R and back to D, the car will not move forward again because the oil is already hot and the seals could not withstand the pressure inside the gearbox. Then repeat the above instruction again. It is wise to replace or overhauled depending on the circumstances, that is the price.
Apr 30, 2014 | 1996 Volvo 960
My 1996 camaro won't move when I step on the gas
Check your linkage if ok ....... you have trans issues most likely torque converter ? ?. Mike J
Jan 11, 2013 | Cars & Trucks
96 camaro stops moving on drive for no reason
I just had the same problem my truck felt as though it shifted into neutral after transmission got hot and then when it cooled it shifted normal, transmission lost high gear.
if your car starts right away the maybe its your neutral safety switch.
hope this helps, I am not a transmission guy, just what I would check first.
Apr 30, 2012 | 1996 Chevrolet Camaro
When the washer reaches the spin cycle it stops. the motor sounds like it wants to work. Now the machine won't work in any cycle but motor gets hot and wants to work
Check and see if the ****** has locked up... try to turn the motor shaft and see if it will move... if not then the transmission is locked... ie. broken...
If it will move then the motor is caput...or broken... replace the motor...
heatman101
Aug 04, 2011 | Kenmore Washing Machines
Transmission works fine when cold but when transmission gets hot car will not move in drive or reverse
SOUND LIKE TRANSMISSION GETTING HOT CHECK TRANSMISSION FLUID LEVEL.IF LEVEL OKAY FLUID + FILTER BEEN CHANGED MAKE SURE TRANSMISSION COOLING LINES TO RADIATOR NOT PLUGGED CAUSING TRANSMISSION OVER HEAT. OR LEAKING TRANSMISSION FLUID.
Aug 29, 2010 | 1993 Dodge Spirit
I have a 94 Mitsubishi Diamante ES. A month ago I noticed that transmission was getting stemming hot after driving on a high way. I let the car cool down and then nothing happened for about two weeks....
theres a good chance you need a replacemnt transmission. Since this problem is real your only option to get it professionaly inspected . We can guess, but a guess isn't going to fix it.
Jun 14, 2010 | 1995 Mitsubishi Diamante
Febi 1997 - 2003 Acura CL Transfer Case Fluid W0133-1930425 Acura Au Logo
22 people viewed this question
Top Febi GPS Experts
Will Halftowaite
Are you a Febi GPS Expert? Answer questions, earn points and help others
