!997dodgeintrepid4.7engine/where is the crankcase sensor located on the engine?
    Problem Solver:
  • 10 Answers
Wow I didn't know that a 1997 Dodge Intrepid had anything to do with laptop questions. unless of course you turned your laptop into a 1997 Dodge Intrepid or alternatively turned your 1997 Dodge Intrepid into a laptop. <-- though I would like to see that one!
Posted on Jan 01, 2014
Where is the knock sensor located in a 2008 Ford Mustang gt
is it the 3.1l or upto 3.9l engine. as there is 3 locations and there is a 5.3.l, what you are looking for is on the right side of the engine, there will be a round sensor on a wire that has a nut on the end holding it down one place is under the intake manifold, another is located in the middle of the crankcase, same looking, but the 3 on the 5.3l has a cover over the sensor what would need to be removed to get to the sensor. so looking at the engine from position one cam end its left side.
Aug 15, 2017 | Ford Cars & Trucks
Where is the crankcase pressure sensor located in a 2004 Pt Cruiser
Chrysler PT Cruiser crankcase pressure Questions ... - Fixya
www.fixya.com > ... > crankcase pressure > Cars & Trucks > Chrysler
Chrysler PT Cruiser cars & trucks crankcase pressure questions and answers. Ask your ... The oil pressure switch/sensor is located on the rear of the engine block above the right axle I believe. Unless you ... Question about 2004 PT Cruiser.
Nov 24, 2015 | Cars & Trucks
Oil in maf sensor
POSIBLE CAUSES:
Over filled crankcase.
Excessive engine blow by caused by worn rings or a scored cylinder wall.
Plugged PCV positive crankcase ventilation system valve or collapsed hose.
Apr 06, 2012 | 2001 Ford Windstar
Where is the location of the crankshaft position sensors on a 97 Cadillac Deville. It stalls at red lights and stop signs and I've heard a new crankshaft position sensor is a possible solution. I've got...
The check engine light doesn't have to come on with a bad crank sensor ,your vehicle has two , one for lower rpm an one for higher speeds . A&B
The two crankshaft sensors are located on the front bank (BANK 2) of the engine block between cylinders 4 and 6. Crankshaft position A sensor is located in the upper crankcase and crankshaft position B sensor is located in the lower crankcase. Both sensors extend into the crankcase and are sealed to the engine block with O-rings. The crankshaft position sensors are not adjustable.
Nov 18, 2017 | 1997 Cadillac DeVille
Cannot find the crank shift sensor location
M112 And M113 Engines
  1. Before servicing the vehicle, refer to the precautions.
  2. Remove air filter housing.
  3. Remove hot film mass air flow sensor.
  4. Remove air duct housing.
  5. Release and disconnect electrical connector at crankshaft Hall sensor.
  6. Remove bolt.
  7. Pull crankshaft Hall sensor out of crankcase.
    CKP sensor location
To install:
  1. Installation is the reverse of removal.
  2. Tighten crankshaft Hall sensor to crankcase bolt to 6 ft. lbs. (8 Nm).
  3. Carry out first initialization and then sensor rotor adaptation using Star Diagnosis tool.
Oct 22, 2010 | 2002 Mercedes-Benz C-Class
WHERE IS THE CRANK SHAFT SENCER LOCATED ON THE MOTOR
The 2 crankshaft sensors are located on the front of the engine block, between cylinder Numbers 4 and 6. Crankshaft position A sensor is located on the upper crankcase and crankshaft position B sensor is located in the lower crankcase. Both sensors extend into the crankcase and are sealed into the engine block with O-rings. The crankshaft position sensors are not adjustable.
Jun 08, 2010 | 1998 Cadillac Catera
Where is it located on engine (2006 KIA optima 2.5 4cyl.) the crank sensor & estimated time to change
the crank sensor should be located on the left rear of the engine nearest the bell housing. the exciter ring is bolted on the end of the crankshaft inside the crankcase. holp this helps. cheers
Jan 23, 2010 | 2006 Kia Optima
Crankshaft sensor location and replacement procedure
It is on the rear of the engine, passenger side. You need to access it from the underside and it is halfway up the block between the head and the oilpan. It is real close to where the engine and transmission meet.
May 23, 2009 | 2004 Chrysler PT Cruiser
1995 lincoln continental wont start
have you checked out the core packs? and if you go to autozone you can get a printed diagram where the crankcase sensor is located also look for the location normally under the hood for the fuel pump relay
Jan 15, 2009 | 1995 Lincoln Continental
Oil sensor
The oil light on your car has nothing to do with oil level in the crankcase but rather oil pressure. The oil pressure switch/sensor is located on the rear of the engine block above the right axle I believe. Unless you have engine noise or suspect low oil pressure, I'd replace it but you could check oil pressure for peace of mind with an pressure gauge if you wish. You may need a special socket to replace it.
Oct 18, 2008 | 2001 Chrysler PT Cruiser
Computers & Internet Logo
David Payne
David Payne
