Question about Sharp Televison & Video
LC40E67UN Optical Cable does not work
I purchased a Sony sound bar with three HDMI's and one Optical input. After numerous tries it would never work. I had previously purchased a BOSE Solo sound bar and could never get it to work which lead to the purchase of the Sony. I was told I could use HDMI's instead, but found out the HDMI on the TV had to be ARC capable. This means the TV had to be Audio Return Channel (ARC) compatible. If the TV HDMI's not compatible, you were left with using the Optical input which did not work, although it is an option on the TV. is there another solution rather than purchasing another TV?
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
gymhasafit
  • 31 Answers
SOURCE: how do I get sound from bose cinemate while watching Bluray with?
You are right I checked the Manual online and there is no Optical in. The other tech was right in suggesting that, Cause it would be the next best thing to HDMI. It only has 1 Analog Audio in, So what I would Recommend is Plugging in all of your Devices to your TV and then 1 Audio cable from your TV to The Bose input. Although this will NOT transfer Digital Audio to Analog Audio. This means if you are going in HDMI then the Audio would most likely NOT transfer to the Bose. In this case you would have to hook up a set of Audio cables (Red and White) From the Blu-Ray to the Bose along with the HDMI. This will leave you with only Audio from the Blu-ray through the Bose. To go a step further you can purchase an Audio Splitter (or Video) then plug your Devices into the Splitter and then 1 cable out to the Bose and just Switch the Input along with the TV. Good Luck!
Posted on Apr 29, 2009
  • 1340 Answers
SOURCE: I just installed a Bose Cinemate II system. HDMI
No,you are not mistaken actually.I really don't have much to offer though.I just want to let you know that I have seen many problems with HDMI cables and no sound.HDMI does in fact transfer audio/video.Even though I do not like to use Wikipedia because anyone can edit the info,I check and see if it is accurate first and does give the best descriptions and is the quickest and easiest to find.This is a newer technology.Any new technology is usually not figured out until about year 5.In year 3,they are able to get the kinks worked out,but year 4 is already in production.They start designing and building the best version for year 5 next.Although 5 years isn't always achieved,it is more of a minimum to see the best possible of the technology.Happens with cars,TV's,VCR's,etc.Prices come down as everyone who wants it is greatly reduced by then also.Anyhow,here is a link to some info about HDMI.Scroll down to Communication channel protocols.Under TMDS there is some relevant info.You may not understand the terminology but basically it seems that there is an internal automatic muting with certain changes in the audio signal.It just sounds to me like the automatic mute is too sensitive right now and will improve over time.There is also some encryption taking place which is basically taking the output,scrambling it,sending it somewhere,and then being unscrambled and reproduced identically.Same as wireless internet.With all the various products being used,everyone has their own way of doing something.Since it isn't exactly made with exact specifications,there are many variations to interpret.If someone were to have ALL components made by 1 company,it would most likely work much better.How many people have that kind of setup though?Very few.There is not 1 company which makes everything they produce,better than everyone else's.Some make better radios,some TV's,etc.Right now,some of the better TV's are Samsung,LG,Vizio.Some better phones are AT&T,Panasonic.Bose has been at the top of the food chain for years for audio for that reason also.They do audio,nothing else,so they can put everything into it.I know this is a bit wordy but that's why I am here.To inform and educate people about things which they most likely don't understand and encourage them to spread the word.Hope you understand this anyhow.Basically,depending on how old your PS3 is,there may be compatibilty issues.With HDMI changing/upgrading rapidly,if your PS3 is an earlier version,it could simply be compatibility because PS3's even were changed as they sold more.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Here is the link for HDMI characteristics/operation.Good luck,Greg
http://en.wikipedia.org/wiki/HDMI
Posted on Nov 28, 2010
Testimonial: "Thank you for your response. I was able to get audio for my PS3 by connecting an optical cable from the PS3 to the Cinemate interface module."
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
How can I connect a sound bar?
Buy a digital optical cable and plug it in the audio output of the TV and into the audio input on the sound bar. If there is no digital input you can run it with a RCA cable (3 cable red, white, yellow) or just simply an HDMI cable.
SONY eSupport How to connect TV Sound Bar system to television
Feb 15, 2013 | LG 42CS560 42 Class LCD HDTV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Jun 23, 2009 | Sony HT-CT100 Theater System
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Nov 16, 2008 | Sony STR-DB930 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Televison & Video Logo
56 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
