Question about Yamaha Electrical Supplies
Yamaha ef4600de stalling with load - Yamaha Electrical Supplies
I have a EF24000is yamaha that stalls when a load is put on it
Hi, Raimo and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
EF1000is stalling
Honda generator won run under load
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
2009 Yamaha EF2000IS EF2000IS OEM Parts
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 29, 2016 | Yamaha Motorcycles
Ybr125 07 rev counter erratic engine stalls occasionally
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
YBR 125 Losing revs and stalling when idle
Engine stalls cuts off above rpm 7500 also idling problem Yamaha YBR250
Yamaha YBR125ED 2005 Service Manual
OEM parts for Yamaha
YAMAHA YBR125ED Owner Manual
Mar 04, 2014 | Yamaha Ybr 125 Motorcycles
04 yamaha r6 runs rough and stalls after bike has warmed up
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
07 r6 rough idle then stalls on cold start
http://www.pashnit.com/forum/showthread.php?12227-Need-Help-R6-stalling-on-me
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 18, 2014 | Yamaha YZF-R6 Motorcycles
2009 yamaha yz250f runs but stalls when put into gear
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yz250f stalls when put in gear
2010 YZ450f starts but soon stops bike stalls FOUND ANSWER
Yamaha YZ250F 2008 Owner Service Manual
Jan 20, 2014 | Yamaha YZ 250 F Motorcycles
How do I fix stalling on my 2006 stratoliner
Hi, Davekerrigan and the usual suspects are:
http://www.ymhmotoboard.com/topic/2006-stratroadliner-stall-issue-fix
Roadliner Stratoliner Stalling Problem in RoadLiner Strat Tech Forum
Stalling issues last ditch effort
Yamaha XV19SW Service Manual
Yamaha ROADLINER XV19SW Owner Manual
Jan 27, 2013 | 2006 Yamaha Stratoliner
High rpm stall
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/152749-low-rpm-hesitation-high-rpm-stall.html
http://www.r6messagenet.com/forums/r6-maintenance-technical/155675-engine-cutting-out-10k-rpm.html
Yamaha YZF R6T Supplementary Service Manual
Jul 27, 2012 | 2005 Yamaha YZF-R6
Yamaha roadliner stalling issues
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary.
6. Failed ignition coil, stator, magneto, points/condenser ignition/electronic module.
14. Fuel tank contaminated with ethanol sludge.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/15-stratoliner-roadliner/7342-stalling-engine.html
May 28, 2012 | 2006 Yamaha Roadliner S
I have an EF4600DE. Everythign looks good but gen unit does not output a voltage.
this is a brushless generator, that means it has a condensor, this is a "normal" fail, see it happen a lo on brushless. Upgrade to a metal can condensor (gets less heat and is a better construction and the problem should be less frequent...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
Jan 15, 2011 | Yamaha 4500 Watt Electric Start Generator...
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Not generating power from EF4600DE Yamaha
Way low voltage. How is the rpm?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 07, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
