Question about Sony PlayStation Portable (PSP) Console
The volume button of my psp does not work
When i try to put volume to my psp, it's still has no sound at all.
I need help. I just had my psp for over a month only.
  • 13 Answers
I think your volume button is broken because I had a similar problem with my psp My WiFi switch wont work when I had it checked the switch was detached from the command it was assigned to
Posted on May 21, 2009
So when i go to turn up my psp the volume control comes on but it will not allow me to turn it up.
Posted on May 28, 2009
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
On my psp the sound went to blank i put the sound to full and it goes down to none by itself
It maybe because the button for reducing the volume may have been pressed too hard in the past that the button had gone in so whenever you leave the volume incresing button it starts decresing by itself.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
My psp volume button will not work can you help but its only the one to turn it up not down
When this happens, it's because the volume button on the inside is messed up. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the volume button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
http://store.richspsxparts.com/clforpsprese.html
Nov 16, 2009 | Sony PlayStation Portable (PSP) Slim...
Volume
is easy just disable the AVS opcion en sound opcions
Sep 28, 2008 | Sony PlayStation Portable (PSP) Console
The vol. is not working on my psp
Make sure the volume is not set to zero. Try raising the volume using the volume buttons located on the front of the PSP.
Make sure the mute setting is not on. Press the (Music Note), third one from the right, located on the front of the PSP® to clear the mute setting.
If headphones are inserted, the PSP will not send any sound through the speakers. To check that the speakers work, unplug the headphones.
Hope that will Fix Ya!
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp
you prolly need a new lcd. go to ebay or google and buy a new lcd or a lcd+backlight combo which will run about 60.00 open the psp and replace the lcd and the issue will be solved.
May 17, 2008 | Sony PlayStation Portable (PSP) Console
My psp sound quit working. it went low and now no sound at all.
I take it the volume control doesn’t change it? If the level went down rather fast the Volume decrease button (-) might have gotten stuck down.
Have you tried different set of ear buds (headphones)?
Mar 21, 2008 | Sony PlayStation Portable (PSP) Console
Psp keys
It sounds like the pc board that the volume buttons are in is damaged or coming loose. Aany repair shop that services PSP's should be able to fix that.
Sep 12, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
255 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
