Dacor MCS230 Millennia Electric Double Oven Logo
Scott Posted on Dec 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the baking element?
I've removed the two phillips screws holding the element to the back wall of the oven but it appears to be saudered.
Stephen
Level 2:
Habit-Forming:
  • Expert 188 Answers
  • Posted on Jan 01, 2014
 Stephen
Expert
Level 2:
Habit-Forming:
Answers
188
Questions
Helped
74510
Points
489
The back of the oven has to be removed also so you can disconnect the terminals from the element.
2 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 12, 2010
SOURCE: bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Anonymous
  • 1922 Answers
  • Posted on Jul 29, 2012
SOURCE: Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
2answers
Changing my oven element
could be different, depending on which oven, but since you don't know, no one else does either. with all due respect. regards,
Oct 11, 2018 • Ovens
Preheat goes to 100 degrees and stays there. All push buttons to 27 in Jenn-air oven work and after 45 minutes unit heats up.Now not heating up at all.
whenever you set an oven it always starts at 100,if that's an electric oven most likely the bake element is bad and the broil element is just working and heating up the oven,when you set the oven to bake both the broil and bake elements get hot.if it's gas most likely a bad ignitor,send the model number if you write back,also if that's an electric oven make sure you flip the breaker so there's no power going to the oven before you try to remove the element,i see people try to remove the element with the power still on and when they pull out the element the wires touch the metal and bang they short out the clock assy.kill the power,remove the two screws that hold the element in place or if this isn't a wall oven slide out the oven,unplug it,remove the back wall and with a meter read out the element,remove at least one of the wires first and then check it,very simple set your meter to 20k,ohms touch the leads to the element where the wires connect to it,if you see a 1 the element is bad or open,if you see anything else but 1 the element is good or closed,hope this helps you out
HOW TO REMOVE FAN FORCED ELEMENT
All I needed was a phillips screw driver, a small hex socket drive and an 8mm wrench.
1. Turn off the mains at the switch board. There might be a switch near the oven or stove too, turn that off as well. Check that the power is off!
2. Remove the screws holding the oven to the cupboards. Mine was held in by 4 timber screws on the edge.
3. Slide the oven out of the wall. I used a small table to support it.
4. Remove the hex drive screws that hold the top lid on.
5. Using a trusted multimeter CHECK THAT POWER IS OFF! There are now exposed power terminals.
6. Undo the supply power terminals and remove the cable. I taped mine up.
7. Remove the back cover - more hex screws.
8. Pull the spade terminals off the heater element.
8. Inside the oven remove the shelves and side racks. They pop off the wall.
9. Pull the rear fan shield towards you. It should pop out at the top and then lift off 2 small tabs.
10. Remove the phillips screw at the bottom of the heater element.
11. Remove the 2 spring clips.
12. The element can now slide down and towards you.
13. Replace the element and put it all back together in reverse order.
Oct 08, 2014 • Ovens
2helpful
How do I replace my oven element
Hello.
Theoven is a particularly sturdy piece of kitchen equipment. It can handle dailyuse and still perform as needed. But of course, as with everything over time,the oven can eventually have some things go wrong with it. The first signs maybe subtle, like your cake not being cooked through, or you may notice the oventaking much longer than usual to come to temperature. When looking inside theoven as it is heating, you may notice tiny sparks along the bake element. Anyof these symptoms may mean it's time to replace the bake element.Instructionsand tools below Screwdriver, Newbake element, Electrical tape, Fiberglass tape, Flashlight1 The first step when it comes to working on yourelectric oven is to turn the breaker off at your home's service panel, orbreaker box. This is extremely important, because most electric ovens require220-volt electricity to operate, and that voltage won't only hit you hard, itcan kill you. Place a sign on your breaker panel stating that you are workingon the electrical. As an added precaution, unplug the oven from the walloutlet. Remove the drawer below the oven chamber to see if the plug isaccessible from there. Otherwise, you may have to pull out the oven a bit tounplug it.2 Be sure that the oven has not been used in a whileand that the elements are completely cool. Remove all of the racks from insidethe oven. If it makes it more comfortable, you can even remove the oven door byopening it and sliding it off of the "arms" that hold it in place.3 Locate the bake element. It resembles a metal tubethat's been bent into a square shape and it is located on the bottom of theoven's interior. It can be quite dark inside the oven, so grab your flashlightand shine it to the rear of the oven's interior to locate where the bakeelement is connected to the oven wall.4 There will be two screws holding the bake element inplace. Remove the two screws and place them somewhere where you will not losethem. Now, pull the bake element out of the oven wall. There will be wiresattached to each "leg" of the bake element. Note: There is usuallynot much wire to work with, so do not pull too hard. Once you have about 4 or 5inches of wire exposed, place a piece of black electrical tape over the wire atthe point where it enters the oven. This will help keep the wire from fallingback inside the hole.5 At the point where the wires are connected to thebake element, you should see a screw. Remove the screws and separate the wiresfrom the bake element. Keep the old element for reference when shopping for anew element that matches the old one exactly.6 Install the new element by connecting one wire toeach leg of the element with the screws, just as they were with the oldelement. Wrap a layer of white fiberglass tape around the terminals. Push thewires back through the holes in the rear of the oven until the bake element isback in position. Use the screws to secure the new element to the oven wall, asbefore.7 Replace the oven door if you removed itearlier. Plug in the oven, then turn the breaker back on. Turn on the oven andtest the new element. You may notice some smoke coming off of the element as itheats up for the first time. This is ok, as these are just oils burning off ofit. The smoke will stop in a few seconds.Thanks.
My whirlpool electric oven broils but doesnt bake. model rf385pcwn1
Hi
The possibilities are a bad Bake element, a broken wire to the Bake element or a bad control board.
You have to remove the Bake element or to pull the range off the wall to perform the troubleshooting and find out which part is bad.
You have to inspect the wires, then remove the wires from the Bake element and check the element for continuity.
If there is nothing wrong then you have to check for 120VAC between each wire and ground and for 240VAC between the wires while the control calls for Bake. If there is no proper voltage then the control board has to be replaced.
However To remove old element, there are 2 bolts/screws on the back of the oven, attached to the element. There will be a silver bar holding the screws/bolts to the back of the oven.
Remove these screws/bolts with either a screwdriver or pliers by turning to the left.
After unscrewing the bolts, pull element out. It will have the electrical wires attached to it with a clamp on each side. Pull wire clamps up to remove the element.
Remove new element from box. Slide new element clamps up into the wires coming out from the back of your oven. (There will be "legs" to hold the element up from the bottom of the oven. These go on the bottom for support of the element).
Tighten existing screws/bolts onto oven through the holes in silver bracket. Do not tighten too much, just make sure is secured.
Turn electricity breaker on and plug oven into outlet. Turn on to 350 and see if it heats up.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 19, 2010 • Ovens
I have a GE oven that the oven part only doesnt come on, the top burners and broiler come on, is this something I can fix?
Most likely a bad bake element. Turn off the power to the range. Remove the oven racks. Remove the retaining screws holding the bake element to the rear wall. Carefully pull the element terminals out of the rear wall. CAREFUL now,the wires will be short. Remove the wires. If you have a volt ohm meter you can test the element for continuity. Set the meter for ohms or continuity and touch one meter lead each to the element terminals. If you get no reading replace the element with a new one. If you do get a reading your ERC clock is bad.
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Feb 24, 2008 • Ovens
3helpful
2answers
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
