Question about Hmdx Rave Portable Rechargeable Bluetooth Speaker
How do I change the batteries
I have hdmx on I have my iPhone turned on to Bluetooth.
Tip
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery...
The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life.
1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand.
2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth).
3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options.
4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically
5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better).
6. Turn off the equalizer: Apple has always suggested turning off the iPhone’s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
on Dec 23, 2009 | Cell Phones
I can't get my jams hdmx speaker to pair with my iPad Pro. The speaker will not even list under "my devices."
If you can, erase the memory on the speaker and mark each Bluetooth listing on the iPad to Forget This Device. Do not be around any other Bluetooth devices. Turn your speaker and iPad off and back on. Let them discover like 1st time. Try again. Patience. Sometimes takes 20 to 30 min. RJ
Apr 25, 2016 | HDMX Audio HMDX Jam Plus blue
Reset code iphone
I believe the only way to make Bluetooth not discoverable is to turn Bluetooth off all together. It's designed to search for discoverable devices when turned on. I only turn on Bluetooth when using specific devices, else it's a battery hog. Google some sites for saving battery life on a 4S and you'll be surprised what is on that you may not need.
Jul 07, 2014 | Apple iPhone 4S
Bluetooth won't come on hdmx jam party and sync with ipod touch 5th gen
Follow the instructions from the set up guide that came with your Bluetooth wireless speaker on how to pair and connect .the speaker with a Bluetooth-enabled media device such as iPod, iPad or iPhone.
Apr 21, 2014 | Apple iPod Audio Players & Recorders
Samsung galaxy stellar bluetooth cannot discover my Jam hdmx speaker.
Check that bluetooth is turned on, on your Samsung Phone which is likely but make sure that your phone is set as visible to all devices. Then try searching again for the bluetooth speaker.
Dec 30, 2013 | Cell Phones
How do you take apart a hdmx jam bluetooth speaker?
On the bottom, there is a rubber "o" shaped pad. Peeling that back, reveals mounting screws.
Sep 08, 2013 | Televison & Video
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Hmdx Rave Portable Rechargeable Bluetooth Speaker Logo
115 people viewed this question
Top Hmdx Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hmdx Audio Player and Recorder Expert? Answer questions, earn points and help others
