Question about Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
High current code on maytag dishwasher - Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB7100AWW Dishwasher how many minimum amps is needed
to find out the amps needed you need to take the wattage that is listed on the information tag on the door of the dishwasher. Take the wattage number and multiply that number by 1000. Take the figure and divide it by the a/c current used to run the dishwasher this total is the minimum amps need for the proper operation of the dishwasher.
Example 35 watts X 1000 = 35000 divided by power supplied say 120 volts 29.1 amps or 30 amps
Hope this helped
Dave
Jan 18, 2010 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB dishwasher. 'High Current' during wash cycle. What do I need to do? Thanks
What problem is the "high current' you mention causing?
Many dishwashers continue to heat the water to a higher temperature to wash and rinse the dishes with. They turn the heat strip on to do this, which causes the dishwasher to pull more current.
Dec 16, 2009 | Maytag MDB7100AWB Dishwasher
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Maytag Dishwasher 2004 Jet Clean
go to the maytag website and they should have a list of codes under troubleshooting if not call maytag repairs
Oct 30, 2008 | Jenn-Air JDB9910 Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher Logo
26 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
