Question about JCPenney Lil City Car Pink Pink
Need new power cord to charge car - JCPenney Lil City Car Pink Pink
I was given a Eee PC seashell.. and they didn't
Dear power cord is use for charging your laptop battery so if you don't use power cord then you will be unable to charge your laptop battery. But this is truth that if your battery charge is okay then no need power cord but tell me bro how can you charge your laptop battery without power cord. This is totally funny. Yes one way, that is you can charge your battery by using dc adapter. But if you do it i am saying you that you just going to spoil your laptop and also battery.
Nov 05, 2012 | Computers & Internet
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
I need a new ac power cord for my laptop that's a 65 watt does the replacement need to be the same wattage?
The replacement power cord needs to be the same wattage or lower. Lower will either take longer to charge the battery or won't charge it at all. But if you get a cord that has too much power it could fry your power supply.
May 03, 2011 | Computers & Internet
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
JCPenney Lil City Car Pink Pink Logo
21 people viewed this question
Top JCPenney Toys Experts
ray gallant
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
