Not recognize battery
I have a Gateway P-6825. Even though I just replace the battery with a new one the icon still displays 'No battery is detected' The battery is definitely ok. Something in the laptop is not recognizing the battery. Any suggestions?
    New Friend:
  • 37 Answers
Your problem is : Laptop can not detect the battery coz the volt sensor in your power system not work, please ask computer technician nearest in your town to repait this your own laptop. Need to change some parts like transistor or resistor in the mainboard, let technician to fix it.
Posted on Jan 01, 2014
SOURCE: Compaq laptop problem
Hi WV,
I am still testing on the battery and so far no problems with the flash drive in. The slow booting is due I think to Avast updating the virus database at the same time. Otherwise it boots OK. I am getting an error at shutdown "SynTPLpr failed to initialize properly" I have also noticed that I don't need to click on the user login at boot time, only place the cursor over the name and it takes off by itself.
Posted on Aug 11, 2008
SOURCE: DVD player on gateway laptop won't recognize dvds
ok you try with CD CLEANER DISC.if its canot help your DVD LOADER having defective please change it.
Posted on Nov 12, 2008
  • 2976 Answers
SOURCE: Battery not recognized
If the battery is beyond charging, it might not be recognized but, all that I've seen could recognize it . There are 6-8 terminals on most batteries. 2 of them close the circuit indicating a battery is in place. If you have access to another battery that is made for your computer, try it. If you still don't have a battery indicated, you could have a problem in the charging system or the bios.
Posted on Feb 20, 2009
  • 3940 Answers
SOURCE: My computer will not recognize the battery. Runs OK on AC.
Since the system is not seeing the batteries the apparent fault is the motherboard connection for the battery. If under warranty , contact Dell, in not, you can try and purchase a replacement motherboard on EBay.
Posted on Apr 26, 2009
SOURCE: HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Posted on Oct 10, 2009
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Touchpad not working gateway-6825
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Gateway New P-6000 P-6822, P-6825, P-6832,...
Replacement battery not recognized
The BIOS of the system has to updated or flashed so that the new Battery is detected by the system.To Flash the BIOS, you have to download the latest version from the www.support.gateway.com website and select the right operating system.
Nov 05, 2010 | Gateway NV5423u (LXWDF02005) PC Notebook
We have a gateway laptop model 7405gx and the battery light is blinking even though it is plugged in. Do we need a new battery? What kind is it? thanks. Judy
Does it still work fine on battery?
If you remove the power lead when the battery is in does it shut down.
If so the batery is probably gone.
Replacement bateries are expensive £77 here
http://www.laptopbatteryinc.co.uk/gateway-7405gx-7410-7410gx-battery-p-3238.html
Jul 10, 2010 | Gateway Performance 500 Deluxe PC Desktop
Power adapter isn't charging the battery when plugged in. Comp also won't stay on since the battery isn't charged and the power adapter isn't being recognized, even though it's plugged in. What do I do?
You need a new power cord. Walmart has a Universal one for about $78. This also happened to my laptop last week and I had to get a new one because it was shorting out. Even had sparks...
Jan 26, 2010 | Gateway 450SX4 Notebook
Manual for gateway p-6825 laptop
try this here
everything for your laptop
Jun 16, 2008 | Apple iPhone Smartphone
Computer doesn't recognize songs on the player
Go to disc utility and click on erase volume, then you will be able to add new songs. Unfortunately, as far as I can tell, you may have to delete the entire volume and start over.
Jan 11, 2008 | GPX MW3816 MP3 Player
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
