We want to play multi player and it only gives single player option
SOURCE: adding wii remotes to play multi players
There is a small button inside the SD card slot door, press it. Then press the little button under the battery door of the Wiimote.
SOURCE: career mode vs quick play players on wii brunswick pro bowling
The web site of Crave Entertainment (the seller of the game) says the following:
Unfortunately there is an error in the manual stating that you can bring your pre-configured bowler into ‘Quick Play’. You can not bring a pre-configured bowler made in Career into ‘Quick Play’. We apologize for this error and hope that you continue to enjoy Brunswick Bowling for the Wii.
So apparently there is no way to have a multi-player game with the individual characters you create which is quite an oversight since this seems like the most common thing people would want to do.
SOURCE: can't play multi-player in call of duty
For COD5 on the wii, there is no split screen or local (in your room) multiplayer. Only online multiplayer and co op in the single player campaign.
SOURCE: Playing WIIs Sonic Zero Gravity
The trick is, you have to sync up the 2nd controller to the Wii before starting the game.
Turn on the Wii, there's a small cover below the DVD drive that you flip down, (This is also the spot where your SD Memory card can go) There's the red button.
Open the battery area of the 2nd Wii remote. You'll see a small red button.
Press both the red button the Wii Console & the Wii remote. Then it should turn on & Sync.
Once that's done, start the game. It will then recognize the 2 controllers.
-T
SOURCE: Xbox 360, certain game no sound
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Menu-Audio
player--Playlists-Create playlist--Now create playlist as you want-Now select
same playlist which you have created-Options-Add-Now if you want to add single
song, please click on song name and song will be added-if you want to add
multiple song, then select "Multi" option from left side of the bottom-Mark the
multi songs -Now press "Done" from left side of the bottom-Now select the first
option of "Play" to play songs of playlist.
Mayank Purohit
