Loss of Audio and picture shift on screen.
At exactly midnight 2013-2014 my tv lost all audio. The picture onscreen seemed to have shifted and enlarged so that there is now a black panel on the left of the screen and some of the menu icons can not be viewed completely as they are below the bottom of the screen? I have tried factory reset and audio and picture settings but problem is still there? Frustrated and confused. TV is just on 2yrs old and not used as often as most tvs as Im at work most of my time.
    Top Expert:
  • Televison & ... Master
  • 74,831 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jun 12, 2017
SOURCE: Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Posted on Nov 01, 2007
SOURCE: Factory Reset wont work...Manual reset?
Your tv might be in showroom mode. Use the remote to open the main menu, go to picture, go to mode, go to power up and make sure that home is selected and not showroom. Many of the controls are disabled in showroom mode.
Posted on Jan 17, 2008
jdbouncer
  • 72 Answers
SOURCE: 42" magnavox plasma tv
I partly agree with imaliszewski the problem is Y buffers (upper & lower). There is 3 parts to the Y board (Y-main, Y-upper, and Y-lower). There was an issue with defective Y-buffers in a memo sent out by the Plasma manufacture. The problem could be that you just got a set of these defective buffers in your panel. Or as Imaliszewski stated a current problem. but if you replace the Y-buffers repace them as a set. If your TV goes out again after changing the buffers. The panel is causing the problem by drawing too much current. That was a Defect I found out why working in a Philips/Magnavox warranty repair facility.
Posted on Dec 13, 2008
KingDWS
  • 1606 Answers
SOURCE: no picture
It sounds like the backlight is out. If you can see a faint image that changes then this is the case. You either need to send in for repair or replace. It can if you are lucky be a connection. You can try removing the video cable and try another source or cable.
Posted on Jul 09, 2009
  • 6 Answers
SOURCE: Black screen but have audio.
It's a pretty common problem. (If this is a plasma your post says lcd but it came up under plasma.) The no picture but sound problem is usually the y sus board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
As this radio shack trc 503 cb radio will only transmit but it has loss it audio sound and no noise as nobody seems to don't why this has loss it audio and soun
If its RX audio you have lost then your audio chip is faulty or the speaker, try an external speaker or new internal speaker
Oct 24, 2013 | Radio Shack TRC-503 CB Radio
Sound loss
Hello
Check the speakers of the TV. If they are OK, check the voltage that comes to the audio output section from the power regualtor section. If the voltage is also OK or seem shorted, the audio output IC of your TV has damaged and the section should be repalce as card basis.
Feb 27, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
VIZIO E470VA LCD HDTV audio and video are not in sync
Go to your On-screen Menu, go to settings, select audio, then select LIP SYNC. You can then adjust the amount of shift to synchronize the pix and the audio.
Sep 07, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have a JVC DVD Player & VCR Model HR-XVC27U. It is hooked up to a Panasonic TV CT-32SL14J. I have Cable. With the JVC, I have lost any audio. If I record a VHS, I get picture, no audio. If I...
Shifting a heavy item, or anything really, can cause damage to either the cable or the port the cable is plugged into very easily.
I recommend replacing the audio cable, or trying an alternate audio output (you may be able to choose between RCA-style stereo audio output, digital PCM and digital optical.)
Similarly, the dvd player may be setup to output audio in a format that isn't matching what your AV receiver is expecting - again a variation of either stereo, digital rca or digital optical.
I hope that helps.
Jul 18, 2010 | JVC HR-XVC27U DVD Player/VCR
Yamaha Roadstar 1700 Midnight sticky shift lever
make sure linkage is adjusted correctly. dry lube the levers moving part
Nov 04, 2009 | 2007 Yamaha Road Star Midnight
Hello my picture seems to have shifted upwards ie the top of the image is now at the bottom of the screen then there is a black line then the next two thirds are above the black line. I think on an old tv...
The problem was not actually the tv the fault was on the satellite box. I unplugged the box from the mains to reset it and the picture was restored to normal.
Oct 06, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Apr 29, 2008 | Sony KV-32FS13 TV
Televison & Video Logo
Top Televison & Video Experts
