Question about Video Game Consoles & Games
Instructions for wipe out for the wii u - Video Game Consoles & Games
My nintendo wii plays all games except wii sports and wii play why?
It could be that the disk is dirty, clean it with a glass cleaner and wipe it with a clean cloth. Good Luck and have Fun!!
Jan 23, 2011 | Nintendo Wii Console
I putmy disc in my wii and it will not read the disc. and it said to wipe it with a cloth and i did and it still will not work
Hi there, unfortunately the Wii suffers terribly from laser problems. Usually cleaning the disc can help but as you have already tried this then you are more than likely to require a new laser. These are not expensive and if you purchase one from somewhere like ebay you usually get the tools and instructions on how to fit it. If the console is under a year old Nintendo will replace it for you. Failing that you could send it to be repaired by a third party but that tends to be quite expensive and not worth it considering how cheap Wii's are nowadays.
Hope this helps
Jan 10, 2011 | Nintendo Wii Console
Code error 32022 what is it
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Click here to download Ninento wii repair guide
Jan 05, 2011 | Nintendo Wii Console
Error message error occurred. press the eject button and remove the disc. turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check wheather the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on.
If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately. Remove the AC adapter's AC plus from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
http://igotwii.com/nintendo-wii-manual-error-messages-page-68-69
Jan 04, 2011 | Nintendo Wii Console
Keep getting error message,remove disc and turn power off
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
How do i reset my wii to factory settings
Format (Erase) Wii System Memory This option is used to delete ALL Channels and ALL save data that have been added to the Wii console and will wipe the system memory clean, as it was when purchased new. Please note that if you also have a Wii Shop Account, that data should be deleted first (click here for instructions).
    To delete ALL Channels and save data
  1. Access the Wii System Settings screen (how to).
  2. Click on the left blue arrow twice to reach the Wii System Settings 3 menu options.
  3. Select "Format Wii System Memory."
  5. If Parental Controls are set, enter the PIN.
  6. If you are sure you want to erase the Wii console's system memory, select "Format."
May 25, 2010 | Nintendo Wii Console
Memory wiped help
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaaaaa16
Dec 26, 2009 | Nintendo Wii Console
Blue arrow won't show up on the screen
Try wiping the sensor bar and the infrared part on the wii remote with a wet wipe, make sure you stand a little bit back from your television set as well.
Nov 27, 2009 | Nintendo Wii Console
We start our guitar hero for wii and it gets to certain point in the game and just freezes. Is it the game or the guitar?
It's either the game or the system that is making it freeze. Try cleaning the disk properly, don't wipe it in a spiral motion. Most people think that's the proper way but your suppose to wipe from the inside to the outer edges.
Jul 10, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
