Question about Behringer EUROPOWER EP2500 Amplifier
How to connect 2 behringer EP2500
Hi there. how do I "chain" 2 behringer EP 2500 power amp from a behringer eurodesk SX2442FX mixer?
tks
robotek
  • 1512 Answers
SOURCE: Behringer ep 2500
sounds like you may have a phasing problem with the 4 speakers connected in series. This has the effect of cancelling the bass out. Check that you have them all wired as say "stripe" to negative terminal on the speaker. I use this as a rule of thumb to be sure there are never any phasing problems. they all(speaker boxes) need to be facing the same way for bass to propagate well. Check that you have bridging OFF and all settings to "stereo" SAny other settings you are not sure on, just ask me here :)
Posted on Jan 19, 2008
Siliconchip
  • 52 Answers
SOURCE: Behringer amp
Hello pare ko.
EP2500 is a pro amp, manufacturer says that. Notorious to me.
Got 5 of these for repair. Clip is of course cause by too much
signal from source. If the amp is still clipped or on protect even w/out
signal in, time to open and do repairs inside. usually a MOSFET
inside P50N06 (50V-60A) is kaput. or MJE15033G and MJE15032G.
Now if blowing main Fuse, main txistor 2SA1943/2SC5200 maybe gone.
Read carefully the setting of your dip switches setting at the back.
This amp can drive 750 watts/ch@4 ohms.
Good Luck From Siliconchip
Posted on Sep 11, 2008
paulm10
  • 73 Answers
SOURCE: Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Posted on Jun 13, 2009
  • 5603 Answers
SOURCE: Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Posted on Jun 04, 2010
Testimonial: "This is just about the most thorough solution I really needed. Which does make my project to fix this amp worth it. Thanks I will try what you say. Thank you."
caroldon
  • 17130 Answers
SOURCE: my behringer europower EP2500 poweramp has a bad
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
I have a Behringer sx2442fx mixer,and when i try to use my aux 1 and 2 channels for monitors it doesn't seem to be working. I sthere a chance that i have a button or something on the board thtas p
Make sure that you have enable the main monitor volume at the end of the mixer. They are labeled AUX1 and AUX2 as well located under the last channel of the mixer. If those are on 0 your monitors won't work
Jan 19, 2012 | Behringer Sx2442fx Eurodesk 24channel...
How to clean a behringer ep-2500
Absolutly, I serviced amps for years and prefer a vac and dry brush over compressed air that can blow dust into controls.
Cheers,
Kevin
Nov 18, 2011 | Behringer EUROPOWER EP2500 Amplifier
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Aug 06, 2011 | Behringer Sx2442fx Eurodesk 24channel...
How to use a mixer board
Input at each channel XLR or 1/4 ", at faders(bottom) are assignment buttons for sub groups or to stereo out put and main faders drive audio to amps.
Feb 27, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Behringer EUROPOWER EP2500 Amplifier Logo
236 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
