Question about Hitachi 27FX49B 27" TV
Fly back lines
The name of tv is Hitachi, When i switch on,its not display on the screen so then when i vary a screen voltage the fly back lines appear throught the screen, i mean the whole screen is covered by the lines.
    Sergeant:
    Champion:
  • 255 Answers
The unit is stating an impending breakdown in the horizontal circuit.bring it to a tech to for further analysis.
Posted on May 20, 2009
I have a hitachi tv 220v,model c21-f800s.but fly back not working.can i get a fly back part no.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 18, 2015 | Hitachi Televison & Video
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Tip
Kitchen table, Screen (G2) voltage adjustment, Course 101
Well, those of you who have no idea why a Screen Voltage (technically known as G2) adjustment may interest you, here is a photo of a bad adjustment (too high).
You may also experience smeared colors… this is caused by a low adjustment. To correct this, we need to get the back off of the TV. It would be a good time to unplug it if you have not already done so. Next we locate the FBT (Fly-Back Transformer).
This is a 20” model and it has 2 knobs. Your FBT may vary, as some slim designs and some large tube models may have 3 knobs.
You will need to look closely at the knobs; they will be labeled “Focus” or “Screen”. On units with 3 knobs, there will be 2 focus knobs and 1 screen. For now, we will be working with at the Screen knob only.
With the adjustments identified, we are ready to plug the TV in (including your standard cable connection) and turn it on… BECARFUL!!! For the rest of this adjustment, we will be working inside of an electrically charged TV. We also need to normalize the picture, so go into your TV menu and adjust the Picture and Brightness settings to the middle or center.
If your TV normally displays a black screen when you do not have a signal connected, ex: Video input 1, then this will be the quickest and easiest setup for you to use. However, if you are not so lucky, you may need to bust through your DVD video collection and find a “between scenes” shot that you can pause on to give you as black of a picture as possible. Eliminate as much light in the room as you can (just remember, you still need to see what your doing)… we want a good view of the screen without the interference of ambient lighting.
Once you have your black screen all set, we are now ready to proceed to the adjustment. If you have lines on the screen, see (HIGH)… if you have color smear, see (LOW).
HIGH: If you have some lines in the picture with a washed out appearance, your Screen voltage is too high. You will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
LOW: If you have smeared colors in the picture that seem to trail of the edges, your Screen voltage is too low. You will need to turn the Screen knob on the FBT clockwise. Do this slowly, until you just see some lines zigzagging top to bottom on the screen. Now, you will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
The final set, switch the TV input over to your cable input and check out the picture. Take a good look at some bright scenes and dark scenes. Do they look ok? Adjust the Picture and Brightness in your menu… can you set the picture to your liking? If so, you are all set. If not, double check your work (remember to normalize the Picture and Brightness setting).
If you are unable to adjust the Screen voltage as described above, you may have a High Voltage problem with your TV. This will require a repair and is not covered by this tutorial.
If you are all set and the adjustment is good, we should have a quick look at the focus adjustment. Return the TV to your Black screen setup. Press the TV menu button to give you nice fixed display to focus. Adjust the focus knob(s) until you have the clearest picture. It’s important to balance the center of the picture with the corners of the picture. If the center is too sharp and the edges and corners are blurry, it is not a good adjustment. Do your best, you are the final judge of your work here.
Once you have finished the adjustments and verified the picture with your cable picture, you are ready to close it up and return the TV to normal service. Unplug the TV, replace the back cover… enjoy!
I hope this was helpful. If you benefit from this tutorial, please leave some feedback.
on Mar 21, 2010 | Televison & Video
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No display on tv screen
there is no password hint and i forgot password
Jun 04, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Picture problem
Sounds like the High voltage fly back is going or has loose connection
Feb 21, 2008 | Hitachi 50UX57B 50" Rear Projection...
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi 27FX49B 27" TV Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
