Question about MotorGuide Boating
What is the thrust on a motor guide BFL4S - MotorGuide Boating
3 Suggested Answers
SOURCE: only have fifth gear and second in reverse
my trolling motor has same problem, I replaced the (5) speed selector swith on the foot control and that solved nothing. I have the side selector switch (3 postiion) on order after testing with a meter
Posted on May 17, 2009
jsbenson
  • 166 Answers
SOURCE: I have a Motor Guide
How does the prop rotate? Is it hard to turn? Have you checked behind the prop for fishing line? Are you getting 24 volts to the motor?
Posted on Jan 01, 2015
I have a motor guide great white saltwater series 109 lb thrust 36 v trolling motor. I hooked the 3 batteries up right but it isn't running right, it's very slow. What do I do with the grey wire which has...
running to slow indicates voltage too low
you will have 3 X 12 volt batteries connected in series ( positive to negative to positive to negative with positive to motor The first battery negative connected to the ground on the motor
the multicore wire cable is for 12 volt draws as in fish finder, light etc and can be connected across any single battery terminals
They could also be for a foot controlled pedal that is forward and reverse operation
that will be explained in the user manual
Dec 06, 2017 | Car Audio & Video
Motor Guide pro series 46lb thrust 12 volt trolling motor, no power to motor
check the plug itself that goes to motor open plug see if wires are broke
Mar 02, 2013 | Boating
Ryobi 902 bandsaw makes high pitch noise. have adjusted all guides and thrust bearing
The noise might not be coming from the blade, but perhaps from the bearings on the top or bottom wheel. Unplug it and open the covers. With the blade still on, turn the wheels by hand to see if you still get the noise. Then remove the blade and turn the wheels independently by hand. Then plug it back in and run the motor (with the blade still off!). Of course with the blade still off, the load on the wheel bearings will be very light, so maybe you can provide a bit of load by pressing a wheel or or caster against them as you turn them. Be careful. Good luck!
Oct 24, 2012 | Ryobi 9 in. Benchtop Band Saw
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Mar 26, 2009 | Boating
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Thrust washers
Install it back as it is, *** it and test the motor for north to south free play, has to have not free play, fly wheel has to by *** and engine has to move free
Jan 25, 2009 | 1994 Isuzu Pickup
Boating Logo
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
