Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Pool pump motor not starting up
I have purchased a new pool pump motor complete unit its a onga ppp1100-02 since i have had it it has had new brushes in the motor i think they said it was fusion you can hear the motor load up but not rotate the pump. this has happened twice . i have drained the filter that is just prior to the pump allow the water to drain away then flick the switch on and off a few times and eventually it will then rotate the pump. i then put the lid back on to seal up prime the pump and away it goes. but after it shuts down on the timer it will not start again. this problem that has occurred doesnt allow the pump to be run on the timer. since it was repaired i have had no issues for nearly 5 months pump runs once a day turning on and off via a 24 hr timer. the pool capacity is approx 90,000 ltre approx. the pump is located about 6-7 mtr from the pool area where it draws from has a large sand filter and the spec's on the pump 1.25 hp with a head of 19 mtres and able to pump 400 lt/min. I was told this was more than capable of handling this volume etc. do you have any advise as to why this would fail so early in its life.
  • craig moyle
    craig moyle Jan 03, 2014
    yes the pump holds prime when the pump is shut off and i think 90,000 lt is about 20,000 gallons. i have just taken back to the company that supplied the unit and they tell me there is nothing wrong electrically so i'm fitting it back up and wait and see when or if it burns out.
  • David Spradling
    David Spradling Nov 09, 2017
    try a check valve
    Problem Solver:
  • 7 Answers
Does the pump hold prime when it's off? If a pump runs dry at first then primes it makes the pump and motor work harder. How many gallons of water is your pool?
Posted on Jan 03, 2014
4 Suggested Answers
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
briones93
  • 119 Answers
SOURCE: I have added salt due to constant low salt
Way too high on the salt.. about 5000 to 7000 ppm. You should be around 2000 to 3000 ppm or 5.6 to 6.6... I had the same issue with my system and it's always the cell..Look inside the cell and if you can see white stuff inside, it needs to to be cleaned... The manual states to soak with vinegar for 6hrs.. I soak mine for 24, flush and soak again for 6hrs and flush again.. Comes our clean.. and the low salt alarm goes away until the next time the cell gets dirty with the white buildup... You can add an additive made by hth called "Cell Saver"..Prolongs the cleaning cycle... After you clean the cell and your filter, change your chlorinator cycle to 10 hrs with your pump to run 11 to12 until the pool clears and then lower to maintain the proper chlorine level.. Good luck and hopes this works for you.....
Posted on Aug 12, 2011
Testimonial: "I am soaking the cell now. Will check it tomorrow and see what happens. "
SOURCE: I have an Intex Krystal
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Posted on Nov 07, 2012
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Are there electric brushes in motor
It depends on the kind of motor you have. Most do not have brushes. Most pool/spa motors have windings and bearings.
Rod
US Parts Center
Apr 14, 2014 | Century New Magnetek Pool Spa Pump Motor...
I have purchased a new pool pump motor complete unit its a onga ppp1100-02 since i have had it it has had new brushes in the motor i think they said it was fusion you can hear the motor load up but not...
It could be the capacitor is bad. The capacitor stores up a charge of electricity which it discharges to start the motor without it the motor cannot start against a load. If the capacitor is good the internal switch may be sticky or faulty.It is located under the back cover of the motor. It is a centrifugal switch that starts the motor on the capacitor and start windings and as the motor spins up to speed switches to the run windings. Check to see that it operates smoothly. Hope this helps.
Dec 31, 2013 | Intex Wet Set Water Filtration Filter Pump...
Pump is tripping circuit breaker
If your pump is tripping the circuit breaker there is a very good change that the motor is bad. you can change the motor or purchase a complete new pump. I would pull the pump and take it to a local motor repair shop and have them check it for you.
Aug 29, 2011 | Hayward 3/4hp Super Pump Inground Pool...
INGROUND pOOL 8.0M X 4.5M sAND fILTER onga psf25 1.5 pUMP / 1100 hP aUTO CLORINATOR yOU PRESS A BUTTON AND MOTOR STARTS UP AND FILTERS FOR APPROX 5 MINUTES THEN STOPS
Its either clogged or overheating or internal fault . Do you have to press the red reset button each time.If so there is a fault with the motor and will need to go to electric motor specialist.
Feb 24, 2010 | RTO Safety Vacuum Release System - SR-500...
Onga water pump for our bore. propeller on motor not moving unless you spin it manually to start
This is probally your start capicator on your motor. It stores extra power to start the motor and when the motor starts an internal switch lets it run on regular current. This is a cilinder ether on top of the motor or in the back of the motor. It's about the size of a"D" cell battery or a little bigger. with the power off you just pull the wires and put them back on the same place on the new one. Get the numbers off the old one and any pool shop or motor shop should be able to help you get one.good luck.
Jan 26, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
190 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
