Question about Intex Wet Set Water Filtration Filter Pump for Swimming Pools
I have purchased a new pool pump motor complete unit its a onga ppp1100-02 since i have had it it has had new brushes in the motor i think they said it was fusion you can hear the motor load up but not rotate the pump. this has happened twice . i have drained the filter that is just prior to the pump allow the water to drain away then flick the switch on and off a few times and eventually it will then rotate the pump. i then put the lid back on to seal up prime the pump and away it goes. but after it shuts down on the timer it will not start again. this problem that has occurred doesnt allow the pump to be run on the timer. since it was repaired i have had no issues for nearly 5 months pump runs once a day turning on and off via a 24 hr timer. the pool capacity is approx 90,000 ltre approx. the pump is located about 6-7 mtr from the pool area where it draws from has a large sand filter and the spec's on the pump 1.25 hp with a head of 19 mtres and able to pump 400 lt/min. I was told this was more than capable of handling this volume etc. do you have any advise as to why this would fail so early in its life.
  • 468 Answers
It could be the capacitor is bad. The capacitor stores up a charge of electricity which it discharges to start the motor without it the motor cannot start against a load. If the capacitor is good the internal switch may be sticky or faulty.It is located under the back cover of the motor. It is a centrifugal switch that starts the motor on the capacitor and start windings and as the motor spins up to speed switches to the run windings. Check to see that it operates smoothly. Hope this helps.
Posted on Dec 31, 2013
  • 1 more comment
  • craig moyle
    craig moyle Jan 03, 2014
    yep i think you are on to it i have had it tested by two electricians today and one says the capacitor is shagged and the other say's there is nothing wrong so i have reind\stalled and are now waiting for it to fail for good then they can replace under warranty. thank you everybody for your assistance in trying to resolve my delema
  • craig moyle
  • craig moyle
    cheers for your help
  • 4 Answers
SOURCE: lost prime
Turn off the pump at the timer and remove the lid to your pump where you empty the debris from the basket. Get a hose or bucket and fill that resevoir with water and get the lid back on as quickly as possible. Turn on the pump and it should start to prime. On the filter, there is a air relief valve. Depending on the filter, it will pinch and twist, or there is a knob to uncrew. Doing that as the motor is running allows tbhe air that has built up inside to puge out. Once a steady stream comes out close the relief valve. May need to tryh it more than once.
Posted on Dec 07, 2008
PartsCenter
  • 125 Answers
SOURCE: lost my prime in my
if this is a flooded suction and when it turns on it keeps pushing all the water out faster than it is coming in you may have a pump that is too big for the size of the line coming in.
also look to make sure you have nothing plugging the lines going into the front of the pump.
Posted on Feb 26, 2009
mattofilms
  • 110 Answers
SOURCE: Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Posted on Jul 07, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
briones93
  • 119 Answers
SOURCE: I have added salt due to constant low salt
Way too high on the salt.. about 5000 to 7000 ppm. You should be around 2000 to 3000 ppm or 5.6 to 6.6... I had the same issue with my system and it's always the cell..Look inside the cell and if you can see white stuff inside, it needs to to be cleaned... The manual states to soak with vinegar for 6hrs.. I soak mine for 24, flush and soak again for 6hrs and flush again.. Comes our clean.. and the low salt alarm goes away until the next time the cell gets dirty with the white buildup... You can add an additive made by hth called "Cell Saver"..Prolongs the cleaning cycle... After you clean the cell and your filter, change your chlorinator cycle to 10 hrs with your pump to run 11 to12 until the pool clears and then lower to maintain the proper chlorine level.. Good luck and hopes this works for you.....
Posted on Aug 12, 2011
Testimonial: "I am soaking the cell now. Will check it tomorrow and see what happens. "
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Are there electric brushes in motor
It depends on the kind of motor you have. Most do not have brushes. Most pool/spa motors have windings and bearings.
Rod
US Parts Center
Apr 14, 2014 | Century New Magnetek Pool Spa Pump Motor...
Pool pump motor not starting up
Does the pump hold prime when it's off? If a pump runs dry at first then primes it makes the pump and motor work harder. How many gallons of water is your pool?
Dec 31, 2013 | Intex Automatic Salt Water System for ...
Pump is tripping circuit breaker
If your pump is tripping the circuit breaker there is a very good change that the motor is bad. you can change the motor or purchase a complete new pump. I would pull the pump and take it to a local motor repair shop and have them check it for you.
Aug 29, 2011 | Hayward 3/4hp Super Pump Inground Pool...
INGROUND pOOL 8.0M X 4.5M sAND fILTER onga psf25 1.5 pUMP / 1100 hP aUTO CLORINATOR yOU PRESS A BUTTON AND MOTOR STARTS UP AND FILTERS FOR APPROX 5 MINUTES THEN STOPS
Its either clogged or overheating or internal fault . Do you have to press the red reset button each time.If so there is a fault with the motor and will need to go to electric motor specialist.
Feb 24, 2010 | RTO Safety Vacuum Release System - SR-500...
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Intex Wet Set Water Filtration Filter Pump for Swimming Pools Logo
88 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
