Question about ASUS Essentio Desktop with Intel Core 2 Quad Processor
Remove a flap
I want to remove the flap in front of the USB port because when its opened all the way it hits the power button so how do I remove it?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Try the following link.
http://www.bhphotovideo.com/lit_files/69504.pdf
Assuming there is nothing in the user manual to assist and that it is a recent purchase, take the base unit back to where you got it from and get them to assist.
Posted on Jan 01, 2014
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
Remove the flap
IT'S THERE TO PROTECT FROM DUST.
Dec 31, 2013 | ASUS Essentio Desktop with Intel Core 2...
HP c6180 error oxc19a0035
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn the all-in-one on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Service the product
Dec 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
I been using this for 5 years now and lately... it just wont turn on. i have to wait sumtimes up to 3 hrs. and it makes a noise. then i press the power button and it will work. Also the power button is...
hello,
is that light flashing amber/yellow/orange??
try resetting BIOS and if that doesn help try second tip:
2: does this PC have USB port with audio ports in the front? if so, open up the side panel of the computer and followr those wire from front USB to motherboard and remove them from MOBO and try powering it up again.....(remember which wire you take off from where, because you will be putting them back if it doesn't solve the problem).
hope this helps, let me know if there are any questions..
regards
Amar Sondhi
Dec 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
GT4016 hit pwr button comes on flashes three
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
Dec 02, 2009 | Gateway GT4016 Desktop PC
Usb ports not working. power is on but computer doesnt detect anything plugged in. win xp
Hi..
Did you try the other port of your motherboard. Do not use the front USB socket of your computer, you need to plug i directly to your motherboard ports. If the same things happen. you need troubleshooting.
moz-screenshot.pngTry uninstall and reinstall of usb drivers
Remove and reinstall all USB controllers
To remove and reinstall all USB controllers, follow these steps:
Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
Click the Hardware tab.
Click the Device Manager button.
Expand Universal Serial Bus controllers.
Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
Restart the computer, and then reinstall the USB controllers.
Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
ICmanServer
Jul 31, 2009 | EliteGroup Computers & Internet
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
Dyson DC07
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Oct 10, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stuck in incline position
Hi.
Chris.
Aug 11, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
ASUS Essentio Desktop with Intel Core 2 Quad Processor  Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
