Question about ASUS Essentio Desktop with Intel Core 2 Quad Processor
Remove the flap
I want to remove the flap in front of the USB port how would I do that
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
IT'S THERE TO PROTECT FROM DUST.
Posted on Jan 01, 2014
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
Remove a flap
Try the following link.
http://www.bhphotovideo.com/lit_files/69504.pdf
Assuming there is nothing in the user manual to assist and that it is a recent purchase, take the base unit back to where you got it from and get them to assist.
Dec 31, 2013 | ASUS Essentio Desktop with Intel Core 2...
How do i use earphones to listen to music and video on my computer
The lighter gray, curved front panel of the computer can be flipped up to expose two usb ports and a headphone jack. Plug your headphones into the round hole.
Diagram halfway through this article:
http://support.dell.com/support/edocs/SYSTEMS/dim4300/tour.htm#1101572
Mar 05, 2011 | Dell Dimension 4300 PC Desktop
Where is the usb port on the sony digital 8 steady shot usb streaming handycam DCR-TRV460 NTSC?
Look on the front of the handycam. there is is a flap that will open, exposing the slots. Its right on the front...but sometimes hard to see. Its by the light and microphone. Hope that helps.
Jun 13, 2009 | Sony Video Cameras
USB suddenly malfunctioning on Dell TOwer
It does sound like your ports on the front might be bad. They usually connect to a seperate port on the motherboard than the rear ones, and I have seen devices short out the front ports, such as a USB music player.
You can remove the ports on the device manager, and they should come back ok, without worry. However, I doubt that is going to help the front ones. I think you have a hardware problem.
If that is the case, the easiest solution is to get a USB hub, and run a USB cable from the rear, to the front of the computer.
Mar 28, 2009 | Dell OptiPlex GX260 PC Desktop
Do you know where to plug an x-plorer guitar into an x-box 360?
umm maybe you got a wrong guitar... the port is supposed to be USB shaped port which fits straight into one of the two slots on the front of the xbox.
Hope this helped?
Feb 14, 2009 | Activision Guitar Hero X-Plorer Controller...
Dyson DC07
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Oct 10, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stuck in incline position
Hi.
Chris.
Aug 11, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
ASUS Essentio Desktop with Intel Core 2 Quad Processor  Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
