Question about Canon S520 InkJet Photo Printer
Prints summary everytime you print anything
Teh printer prints a summary everytime you print anything
  • 555 Answers
You can disable this option at the printer properties. I don't remember what tab it's located. Just open printer properties, check on each tab and remove the check mark to disable this function where it's indicated.
Posted on Sep 04, 2009
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Fax summary page prints everytime the phone rings.
is internal software problem, needs to be update firmware.
Aug 07, 2010 | HP Photosmart 2710 All-In-One InkJet...
I tried to print a document from internet, there is a message on my monitor telling me that J4680 is printing, but the hardware (printer) is not doing anything. I did run the Self-Test and the printer...
go to the printer page right click on the printer icon that shows the name of your printer
and select as default porinter
if there is any docements in the que try and cancel the documents and see if it gets deleted
again select teh printer as online
and go to the properties page and try to print a test page from teh printer and it should print
and if it does not print disconnect and reconnect teh USB cable from the back of the printer
and try again to print a test page from the printer and this should resolved the problem and still if nothing happens let us know the status and we will help you further with the issue .
BEST OF LUCK
thanks
regards
Hamid
Feb 19, 2010 | HP J4680 Office Jet All-In-One Printer
Print too small
it's just the paper setting, try to setting the paper correctly on the printer properties
Jun 08, 2009 | HP Photosmart C7250 All-In-One Thermal...
Lower light blinks on everytime I try to print anything and nothing prints
Check for any paper jams, I think the orange light mean that there is a error and therefore cant print, check incartriges and other areas inside
Apr 13, 2009 | HP DeskJet 845c Printer
When asked to print, it prints:Filrname, Directory, template, title, subject, arthur keywords, comments, creation date, change number Last saved on,Last saved by, Total Editing time, last printed on, I...
If you are using Microsoft Word, click Tools and then Options.
Once the Options windows pops-up, click the Print tab and UNCHECK Document Properties.
Document properties - Prints the document's summary information on a separate page after printing the document. Word stores summary information on the Summary tab (File menu, Properties command).
Nov 15, 2008 | HP Office Equipment & Supplies
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Summary page
hi dear,
it's not from your printer...but the information from your microsoft word, opening your word document, choosetools, option choose print
oke release a mark from document properties
oke
print again
goodluck
cropp
Mar 27, 2008 | Office Equipment & Supplies
Printing is streaking
What exactly did you clean on this machine? Also, when you say it streaks, is it when you're printing or making a copy?
Jun 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon S520 InkJet Photo Printer Logo
57 people viewed this question
old marine
old marine
