Question about Dryers
Broken Kenmore dryer 80 series
Hello I have a Kenmore clothes dryer (80 series) and it having a problem,the motor is working and the heat is coming in the dryer but the part where the clothes go to get dry is not turning ,what could be the problem ? and what can I do to fix this problem? I would be very grateful for your help ,I cannot afford to buy a new one at this time so I would like to fix this one with your help of course ,thank you so much.and have a great day.
  • 3 more comments
  • Dave615 Oct 21, 2007
    Hello solution guy,thank you for the information,you give me some hope that it can be fixed,I have the other information you requested
    Model#  110.72812101
    Type DWSR-NAT-1206006-CV22
    Thanks again ,please tell me how exact and what part I need to remove to change those service parts,either back,front or top,I am not sure where to start.I will wait for your reply to try to order the right part and fix the dryer,you have a nice day.
  • Dave615 Oct 22, 2007
    Solution Guy Thank you so much for your information and explanation on how to fix my dryer ,I probably will be ok now thanks to your information,I will contact you if i come into any problems thanks you again and have a great day,you are really a Guru,by the way do you know about Pioneer DVD recorders?I am having problems with mine,it is not recording and its almost new?please let me know .bye.
    David
  • Anonymous May 27, 2008
    dryer started making a noise then drum was not working proper. belts is still good
  • droff101 Dec 28, 2008
    Kenmore 80 series electric dryer model 101.62872101 heats and runs, but doesn't tumble. What part(s) do I need and how do I take it apart it to fix it? Thanks, Martha 12/28/08
  • mcbn Apr 26, 2009
    We have a Kenmore 80 Series dryer, model 110.60802990. The drum suddenly stopped turning. I took the back off the dryer in hopes of locating the problem (perhaps a broken belt????), but there are two more plates blocking the interior parts and I don't know where to go from here.
    President:
  • 331 Answers
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Posted on Oct 18, 2007
  • Tracy Farrell
    Tracy Farrell Oct 21, 2007
    Dave, access to the cabinet is simple.
    UNPLUG THE DRYER FIRST!
    1.) Remove the 2 phillips screws under the lint screen flap.
    2.) Use a flat screwdriver... pry the top panel up at both corners and lift the top panel up all the way like the hood of a car.
    3.) Use a 5/16" nut driver or socket and remove the 2 screws holding the front panel to the cabinet.
    4.) Tilt the front panel forward and remove the wires going to the door switch. (remember their location for reassembly)
    5.) Lift the front panel off of its' clips and set the panel aside.
    6.) Remove the drum.
    Now you have full access to the interior cabinet. The part number I gave you, 4392065, has instructions in it. Just follow them and rebuild the dryer in reverse order of disassembly.
    *TIP---> After you have the rollers installed, put the drum back in. Then slide the belt over the top of the drum and line it up with the worn "belt line" on the drum (you'll see it). Then go down and install the idler pulley. Follow the instructions on how to route the belt.
    Now, kneeling in front of the drum, rotate it by hand several turns. Make sure to get the felt seal at the rear of the drum seated properly... that is... no felt should be sticking into the drum area. It should be uniform all the way around.
    Since this is your first one, it'll take you about an hour to do. But it's worth it, this dryer is manufactured by Whirlpool and in my opinion, built like a tank.
  • 3 Answers
My Kenmore 80 series dryer takes about 3 or 4 times before the clothes are fully dry. The motor runs and the drum tumbles but the problem is with the heat.Thanks!
Posted on Dec 19, 2009
How do I get to the belt to change it?
Posted on Feb 15, 2009
I have a Kenmore Dryer and just purchased the part I needed the problem is I took 2 other parts off before and want to make sure I get the right connections on. I have a MH4233 Kenmore 80 Series Model 66822694. Do you have any instructions that tell how to put back on the coil and 2 thermostats.
Posted on Sep 22, 2011
    Problem Solver:
  • 9 Answers
I also have a Kenmore Dryer and just purchased the part I needed the problem is I took 2 other parts off before and want to make sure I get the right connections on. I have an MH4233 Kenmore 80 Series Model 66822694.
Posted on Aug 08, 2018
4 Suggested Answers
SOURCE: Hello I have a Kenmore clothes dryer (80 series)
Sounds as though the drive belt is broken or loose,check the pulley on the motor.Feel the belt if it's just loose you might be able to tighten it otherwise you will probably need to replace it.Regards Bigfoot57.
Posted on Sep 13, 2009
Testimonial: "Thank you so much for your information and explanation on how to fix my dryer ,I probably will be ok now thanks to your information,I will contact you"
jsrock516
  • 5911 Answers
SOURCE: Broken Kenmore 80 Series dryer
Sounds like you have a simple broken belt problem.  If you are sure the motor is working and the heating circuits are functioning, but the drum does not turn, the drum belt probably broke.  They are inexpensive to replace and are carried by almost any appliance repair store.
Posted on Oct 21, 2007
jumptrout51
  • 3361 Answers
SOURCE: Hello I have a Kenmore clothes dryer (80 series).
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Posted on Oct 26, 2009
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Oct 21, 2007 | Dryers
Dryers Logo
12,167 people viewed this question
Top Dryers Experts
Marvin
Marvin
