Question about Nintendo New Super Mario Bros. for DS
I am looking for the water pipe in mishrise one is above ground and the one i looking for the one that is underground
    New Friend:
Have you ever played mario games on mariogames66.com? Mario Games SUPER MARIO GAMES mariogames66 com
Posted on Jan 23, 2014
Need a solution for underground pipe leakage?
For underground pipe leakage solution, I suggest Excavation Gold Coast. They specialize in the locating and clean exposure of a variety of services using the new and innovative technique of Hydro-Excavation. Hydro vacuum excavation utilizes water to loosen up the soil and vacuum to dig the hole. They provide 24x7 service. To learn more about it you can see the link given above.
Jan 30, 2018 | Video Game Consoles & Games
Im using a salamander heater to thaw out frozen pipes in a double wide, been running for 3 hrs. I still do not have water! Could the underground pipe be frozen,if so how do I fix this?
just keep heating it, if it is frozen underground heating will be the only way once unfrozen let one tap drip a bit to stop it from freezing again
Feb 19, 2015 | Water Heaters
What does it mean if the psi drops 5 to 10 psi on the pool filter
Restriction before pump impeller or clogged impeller. Check:
Dirty skimmer basket, not enough water in pool, stuck weir gate in up position, plugged pipe coming into pump, if in ground pool, then yes,the pipe underground. It is not a restriction after the pump like dirty filter. If it was, pressure will rise!
Feb 11, 2015 | Pool & Spa
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2014 | Water Heaters
Sump Pump Ejector line (outside) freezes.
IF the drain on the outside of the home is in the ground and is not below the freeze / frost line, it needs to be changed. If the drain is above ground at any point it needs to be unhooked at the point it exits the structure and diverted to the ground with an elbow. A splash diverter would be placed under the elbow.
Jan 09, 2018 | Washing Machines
I have williams floor heater model#4505622 which was installed April, 2010. It was working in Nov, but there was heavy rain that month. One day in Dec, 2010, it stopped working. The pilot is off. I called...
Your final question is an excellent one!
YES!-- they SHOULD BE!-- Are they truly, tho?- I doubt it!
and unless the power feed, and the thermostat connections come in from above the floor line, there invariably will be ways for water to get into this box!
So-- Can you shine a light down thru the floor grating, and can you see signs of water having gotten into the equipment?-- Can you remove the grate, and check it out closely?
Let us now what you find-
MackB
Jan 08, 2011 | Williams 4505622 (NG) Gas Heater
How do you prime a sta-rite mse-6 deep well pump?
Take the pressure guage off and pour water in the hole untill it fills the pump, then screw the guage back on and cranck it up. You may have to do this a few times depending on how deep in the grownd the water is.
Jan 26, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
My house's underground drain pipe froze. It's been that way for 2 days now. It's plastic tubing, and we tried putting warm water and everything, but it wouldn't defrost. I live in Toronto and it's about 0-...
i would suggest calling a plumber as they have special tools they can use to defrost it. i would also suggest in warmer weather that you have the pipe dug up and buried lower in the ground to prevent it from freezing again
Jan 05, 2010 | Plumbing
Nintendo New Super Mario Bros. for DS Logo
88 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
