Question about HP Office Equipment & Supplies
Cable came off
I have a cable, it is about 1/4" wide and is smoke/clear. came loose from the left side of the printer. where does it run in front of or behind?
    Problem Solver:
  • 12 Answers
Runs behind the printer, it's the USB cable. The other end is probably 3/4" wide and flatter right?
Connect that to computer.
good luck
Posted on May 20, 2009
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
On a 02 Suzuki xl7 what side of the car is the #1 cylinder. I am trying to find the 02 sensor (Bank 2 Sensor 1)
#1 is left side, drivers, or in UK its be passengers. side/.
the word LEFT works on all cars world wide. and is clear.
we drive LHD cars here, but not in UK, or other countries.
the #1 cylinder the most forward cylinder on all v6s
just one glance from top and bingo.
H27engine
or 3.6L>
bolt the H20 to h27a are left side, #1 see photo.
3.6L
. The right bank of cylinders are number 1-3-5 and the left bank of cylinders are 2-4-6. The engine firing order is 1-2-3-4-5-6.
so Bank2 is RIGHT. as is B2s1, front. right.
as clearly seen here, see how #1 sits forward?
we have posted this answer here, like 10 times.
now 11th.
Aug 12, 2011 | 2002 Suzuki XL-7
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
Random elec probs ( I suspect a ground issue) 1 garage door opener built into visor and sunroof and the two courtsey lights (map reading lights stop working. Both driver and passenger side (The lights tied...
Yup, grounding problem.
There is a grounding strap from the engine to the chassis. It is either loose, corroded, damaged, missing, or otherwise not making good contact with the engine or chassis. If you can't locate it, then ground has been using the "pigtail" wire coming off the negative battery side.
If you had the battery or cables services recently, then the wrong negative cable was installed. Installing a ground strap (AutoZone $8) from engine to chassis is better anyway.
Sep 24, 2009 | 2001 Volvo V70
Canon NP6551 copier provides illegible display of words.
Sounds like what are known as Bias bars. These can often be cleared up with a thorough cleaning by a professional B&W copier guy.This should be done at least twice a years.
Mar 24, 2009 | Canon NP 6551 Black and White Copier
Clear carrier jamed
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
Solution:
Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
Clear the carrier jam
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark P4350 problem, anyone have a service manual?
Its the encoder strip if come out from one side ur printer is defective it cannot be replaced back..if it is out its position please
Use this link to trouble shoot:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:479:0:0&framed=&docid=ENUS22722&relevance=0
Mar 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Seeker5211
Seeker5211
