Question about Vizio M550SV 55 in. HDTV
No imaging, have sound, backlight, etc.
Vizio M550SV Problems: 1. No imaging (picture) 2. Has sound 3. You can see backlite is working when you turn tv on or change input selection. Vizio Emblem lights up as well.. Tried so far: 1. Replaced Main board 2. Replaced Power Board At this point Im not sure where to turn. Could I have gotten a bad main board? Could it be the actual screen itself and not the boards? Thanks in advance for any help. Thanks Greg Baldwin
  • 451 Answers
It may be an input cable problem. Check hdmi and or coax cables to make sure they are not damaged . If you have another tv hook cables up to it to make sure they are working. Hope this helps.
Posted on Dec 31, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: Orange light is all I get.
99 percent its the mainboard not the powerboard, especially if you have amber led. The mainboard swap is pretty simple if you can get the parts.
Posted on Jul 19, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
FIGURE OUT WHERE TO START DIAGNOSES
https://www.youtube.com/watch?v=sDwZQIZB... try this video 1st.sounds like your problem.
Jul 07, 2016 | Vizio E701I-A3 70-inch LED-backlit LCD TV...
My Vizio Smart TV has no sound
Sounds like you may need to replace the audio circuit board. If you are comfortable with taking apart your tv, you can find a dealer on this site who provides new and refurbished circuit boards for televisions. It is a shame that your tv is so new and causing you issues. Good luck and have a great day!
Aug 30, 2015 | Vizio M550SV 55 Inch Class Edge Lit Razor...
1.5 year old Vizio 55" M550SV now has color vertical lines edge to edge. Audio ok. Image here: http://jaxehost.com/vizio/m550sv.jpg Likely cause. Happened after first cold night. Worked ok first 10 mins,...
it looks like the panel is going bad or the main board. try to change the main board if that does not fix your problem the panel is bad. open the tv and get the main board part number and look for it on ebay.
Oct 24, 2013 | Vizio 55" M550SV 1080p 240Hz Widescreen...
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
Vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
Feb 04, 2011 | Vizio VO47L 47 in. LCD TV
I have power but no picture.
Hello tbdbitl, First I want you to check all of your inputs, to make sure you have proper connectivity. If your connections are good, then you may have one of two problems which are: 1) defective backlight 2) defective power supply inverter In both of these cases you will need to perform one test. With the TV in a dark room, turn it on and using a flashlight look at the screen and see if you can see an image, if you can see an image then the problem is either in the inverter or the backlight. In either case you need to have this looked at by a qualified TV technician, because these parts are not user servicable. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 09, 2009 | Vizio L32 32 in. LCD HDTV
Sound no picture
Hi bnkbaker, Sorry to hear your having TV problems. We need to check your backlight inverter, While your tv is on and you can hear audio(sound) take a flashlight or a lamp with a bare bulb and shine it on the screen, look very closely at the screen and see if you can see a video image. Let me know what you find and I can assist you further, please rate this solution. lone99star
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio M550SV 55 in. HDTV Logo
122 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
