Question about Sony PlayStation Portable (PSP) Console
PSP DOES NOT READ DISCS/ UMD GAMES AND DVDS
WELL THIS GUY SAID TO PRESS THIS SWITCH AND THE LASER LIGHTS UP WHICH IT DOES BOT THE MOTOR SPIN THING DOES NOT SPIN CAN U TELL ME WHY PLEASE I REALLY NEED SOME HELP MY EMAIL IS foxy_1994@hotmail.co.uk if u need to tell me anythin and my mobile is 07716537216 if u need to contact me in any way ,,,
thanks josh
  • Anonymous Dec 29, 2007
    put game disc in psp will not read any games at all.Its an american psp, but son put english game in and changed the region, i think. Can we change the region back and how?
  • 709 Answers
HI Josh,
It sounds like your UMD is Shot man.  I have tried to help you. Do you think your skilled and patient enough to Disassemble the entire PSP to REpalce your UMD Drive? If so , Write me vback.
Posted on Oct 20, 2007
Evey time i but in a umd it comes on and then says disk can not be read
It could be many things is the can be a bad lazer, disc rotating motor is stuck, or bad motherboard in a worst case scenario. You can check if your lazer and your disc rotating motor is working if you open your umd slot with the psp on and with a small toothpick there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive If you press this down, you should see the disc motor spin and the laser light up red. If they are in working order then it could be something wrong with some of the other hardware in the psp itself. (Caution: Do not stare directly at lazer) If one of the motor (Lazer or Disk rotating motor) are twitching or trying to move there could be some dust in the gear preventing it from turning you can try getting a needle and try to move the gear manually. If this does not work your most likely going to need to send it in for repair. Hope this helps please rate thanks!
Feb 26, 2011 | Sony PlayStation Portable (PSP) Console
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
Dreamcast is not reading disk says please put in disk
There can be 1 or 3 problems with this
1 The laser lens needs to be replaced
2 The motor that spins the disc needs replacing
3 The motor that drives the laser carriage needs replacing.
90% of the time its the laser lens
Jan 25, 2010 | Sega Dreamcast Console
Always in loading mode
the most common reson for this is damaged DVD/CD/s that are scratched or dirty with finger prints on playing surface. The next most commo9n is a dirty iris, which is the scanning eye of the laser. Try using a cleaning disk to clean the iris( $20) and getting a DVD/CD repair and cleaning kit. I experience most of these problems from using Hired movies and it is really frustrating!
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Computers & Internet
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
HELP PSP WONT READ UMDS!!!!
hi i just fixed my sons it wasnt reading umd's every thing else worked so have a look were the threaded rod runs threw the laser, in the centre at the back of the laser there is a little tab with a stamped groove in it make sure the laser is up against the disk spinner when turned off push the tab against the threaded rod hopefully it has seated (you ned a good light plus i used long metal twesers to push it down, easier to see on 2000 model than the fat one but you can manage good luck)
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
145 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
