Question about Rangemaster Kitchen Ranges
Rangemaster broan hood squeals when running
Range hood sounds like bearings have no oil?
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
hiltonjug
  • 612 Answers
SOURCE: range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Posted on Oct 01, 2009
milten1
  • 1304 Answers
SOURCE: I have a rangemaster LEIHDS120SC cooker hood. The
thats a minimum
you should be ablt o go as high as 950
but i would not go higher than 850
to stay efficent
Posted on Oct 21, 2009
  • 394 Answers
SOURCE: Can't get the light bulb
Hi, I am Steve, lets get you some help
The hood manufacturer typically uses screw in led lights. you need to turn the light as if removing a screw (anticlockwise movement).
They may be a bit stiff but a light upwards pressure and a twisting of the wrist should see it turn and come out.
Posted on Feb 03, 2011
  • 1583 Answers
SOURCE: Broan Allure range hood fan
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
Posted on May 19, 2011
The fan motor makes a noise but doesn not start rotating, if you rotate the fan the motor kick in and continues to work until it os turned off.
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Jan 17, 2011 | Broan-NuTone Broan Range Hoods Rangemaster...
Need a elec motor for my rangermaster hood
There are a bunch of those series hoods... need to know the exact model number....
But...
Here are the parts for those hoods and there are motors for most of them...
http://parts.broan-nutone.com/broan/Shop?Dsp=30000&OFFSET=144&PCR=1:1000
heatman101
Jan 10, 2011 | Rangemaster RM60000 Broan Pro Style Wall...
Installation
May I get the make and model # so i can get you the install manual
Jun 16, 2010 | Rangemaster Broan 614804 BALLISTA 48IN...
Range hood blower motor - rangemaster
Oct 01, 2009 | Kitchen Ranges
How do we adjust the feet!
You should have a small tool with the rangemaster that turns two adjusters at the front of the cooker at behind the plinth panel
Jul 19, 2009 | Broan-NuTone RangeMaster RM523604...
Are the rangemaster light lenses the same for all of his hoods
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 22, 2009 | Broan-NuTone Broan Range Hoods Rangemaster...
My Hygena cooker hood fan (model APP2540) stopped working.
this sound like the pcb for all your cooker hood spares visit our site
You-Tube video "8eLuShj-RAg" placeholder (do not delete)
Feb 22, 2009 | Rangemaster Broan 614804 BALLISTA 48IN...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
55 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
