SOURCE: car alarm preventing car from starting
I am having trouble also but I need to know how to disconnect the alarm. I would appreciate it if you could help me out seeing that you have disconnected yours. Thank you
SOURCE: 2002 Jeep Liberty Limited 3.7 V6 Auto with 4wd- Factory alarm system malfunction
all alarms have disable function usually located down underneath the driver side, look for a small toggle switch or momentary switch, turn the key to the on position , click the switch once or twice to the small red l.e.d light stays on constant.
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
SOURCE: cobra car alarm
check if the switch in the bonet is damaged (sometimes working under the bonet you could damage the switch and miss it)installing a new battery should not affect the alarm
SOURCE: car alarm how to reset a cobra alarm after fitting a new batt.
i put a new battery on my car and now the alarm will not work
