Question about Omnitech 9 Sheet Crosscut Shredder OT-NXC8PA
After emptying basket, motor won't turn on at all
Product was working fine. i shut it down to empty the wastebasket and it will not restart at all.
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Runs reverse auto
From your manual!
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Apr 06, 2013 | Coffee Makers & Espresso Machines
Washer won't6 empty water after rinse cycle code F 50 appears
F50 means that the motor stalled. An F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. You will need to verify that the basket can turn freely; If it does not and this machine is new, then make sure bottom shipping pack has been removed or determine what is the cause of friction. If the basket turns freely, you will need to perform test checks with the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. I can help you thru this process, or if you are not comfortable doing it, you can hire a qualified technician.
Hope this helps.
Aug 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Shredder stopped suddenly and won't work
If you are unable to clear the jam, turn off and unplug the shredder;
remove shredder head from the wastebasket and carefully remove any paper extending
below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
if still do not run follow the next steps:
1. Make sure shredder is plugged in and
switch is in automatic [I] position.
2.Wait 15 minutes for shredder to cool
down before trying again.
3.make sure that the shredder head is in the correct position, if is not it will not run
please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
Jan 11, 2010 | Fellowes P70CM Shredder
Basket doesn't spin when emptying wash water
remove door switch and tape the wires together, if it works fine now. replace door switch!
Jan 11, 2010 | Kenmore Washing Machines
I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
It's not an industrial shredder and has a low daily capacity, designed only for small office use.
May 02, 2008 | Computers & Internet
Omnitech 9 Sheet Crosscut Shredder OT-NXC8PA Logo
62 people viewed this question
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
