Question about Sharper Image Turbo SM420 Handheld Steam Vacuum
The locking tab on the bottom of the nozel of my steam wizard broke.
Steam coming out from handle not mop pad
Hose is off or broke at bottom of handle...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Mop is not making steam
Ours did this when the wires broke off inside. It has screws (8, I think) that hold the front to the back. The connections are near the bottom where the cord goes in. Unplug it first, of course. Look for any fraying or damage to the wires.
Mar 25, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The cleaning head of the vacume does not lock into position when I pick up the vacume, therefore when I raise the vacume th cleaning head just lays down.
The mechanism that locks the head into place is broke. Prob a plastic tab that broke off from so much use.
Feb 09, 2010 | Vacuums
I can't get the floor brush to stay on
Sometimes the locking latch gets broke off. You may need to replace the swivel elbo.
Nov 28, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Power nozel N115M
Remove all bottom plate screws and pull off the top of the nozel. There is a white plate over the brush roll simply pull that up by releasing the tabs. There is your belt. If the belt is good then there is a short in your wands and you have to replace them. I can do that too. Call 1-800-948-1358 and ask for josh or buck mon.-fri.9am-6pm est sat.9am-2pm est
Apr 10, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I need parts
Call them at 1-800-798-7398
Have the model number, the country it was made in and the date it was made. All found on sticker on bottom of unit. They are foreigners that answer the phone, so be prepared to spell everything. It takes 3 weeks to get the parts but I found them to be inexpensive.
The part you need is called steam pocket frame and it cost about $15 from them. I just ordered one, mine broke too.
Jan 09, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
Sharper Image Turbo SM420 Handheld Steam Vacuum Logo
Top Sharper Image Vacuums Experts
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
