What could be the problem with a Prima LC3227P flat screen TV. Power light shows operation but there is no video or audio. Any suggestions?
  • Dennis Ryan May 20, 2009
    I don't know why this question is under "Projection TVs". This is a flat-panel LCD television.
  • 355 Answers
Hi, I want you to first unplug your TV and unplug the cable box (if you have one) and unhook the cable from the TV, wait 2 minutes. Starting with the cable going into the TV, rehook that first. Then restart your cable box (if applicable), then plug the TV power back in. Check the "Tuner Mode" control for the correct setting. Next, run the "Auto Program" feature to find all available channels, this can take up to 10 minutes. Once done with auto-program, press the AV button on the remote control and make sure the correct signal source is selected (Should correspond exactly with source where you hooked in the cable to the TV). If you are running in PC mode, the video signal must be present or the TV will turn off. If this does not fix the problem, please respond with the name of the cable/sat provider you are using as well as if you have other TVs available for other checks, are all cables free of breaks in the cable as well as all end fittings in order. and lastly if no cable box, is the cable directly coming from the wall to the tv.
Posted on May 20, 2009
  • Rohit  Asthana
    Rohit Asthana May 20, 2009
    Please click on this link and follow the instructions.
    If this does not work then reset to the original factory settings by performing the following steps:
    1. Press the MENU button on the remote control to see the onscreen menu.
    2. Press the CURSOR DOWN button to highlight the INSTALL menu, then press CURSOR RIGHT to enter.
    3. Press the CURSOR DOWN button repeatedly to highlight the FACTORY RESET control, then press CURSOR RIGHT to enter.
    4. Press CURSOR DOWN to select “YES” to reset the original factory settings.
    5. Press the MENU button repeatedly to clear the menu from the screen.
  • Rohit  Asthana
    oki
    i want to let you know that lcd panels have a tube across the bottom
    that's called a cold-cathode fluorescent light (ccfl), and they do go
    bad. the ccfl provides backlight to the screen, which means if that
    were the problem you'd still be able to see something on the screen, it
    would just be very dim.
How do I troubleshoot my TV problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 26, 2015 | Vizio E-Series E470I-A0 47" LED TV...
42" INSIGNIA/PRIMA We lost the picture and then 20 min later lost the audio. Changed the main power board, got the power light back but still no audio or video. Any ideas?
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Insignia 42 Class 1080p LCD HDTV
PH-50T18 Prima The picture doesn' twork. Sound works. any suggestions
There is a power supply failure and this might need attention of a qualified service technician
Jul 11, 2012 | Televison & Video
I Have a Samsung flat screen ser# LNS4692DX/XAA that video went out and went to dark blue on all channels,still have good audio but cant even get a menu screen any suggestions?
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On
Do you get Menu screen now or tv shows channels?
If problem still not solved then let me know how old is this tv and any related info about problem like storm or lightning in area that caused this problem in tv. Does tv show picture in dvd playback?
Thanks.
Nov 04, 2010 | Samsung SPN4235 42 in. Plasma HDTV
I have a Prima P5017 TV I need the specs. I need
I have a Prima TV Plasma Model P5017 The TV turn off alone and when I try to turn on the red light change to the blue and five seconds later turn off.
Mar 28, 2010 | Televison & Video
LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Nov 09, 2008 | Prima C2012 TV
My HT3061P Prima tv, has the black screen, but the audio is very good.
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
Oct 15, 2008 | Prima CV2011 TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
