Mitsubishi WT-46809 will not turn on and stay on
When turning on my Mitsubishi WT-48609 it will turn green for about 4 seconds and then turn off. When pressing the input and menu together for five seconds it flashes me a code 22 or according to another post a problem with the short protection. Can you please give me suggestion on how to fix this or what I should order? It just started doing this a couple of days ago. Thanks.
Rich
5 Suggested Answers
  • 1694 Answers
SOURCE: MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
ctf1800
  • 4402 Answers
SOURCE: mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
eagle338
  • 4889 Answers
SOURCE: MITSUBISHI WT-A42 ERROR CODE 22 "SHORT PROTECT CIRCUIT"
error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this. we need to test some parts to see what this is. the most common is a shorted convergence circuit. a repair on this would range around 400.00. You should check using a multimeter and also you should be good at soldering
PS:I strongly advice if you don't have experience in electronics then better leave this job to a tech
Posted on Feb 17, 2008
SOURCE: my mitsubishi wt 46809 will not stay on.Iturn it
put it out on the curb and go buy an american tv!
Posted on Feb 08, 2010
Power will not stay on
A problem in a certain parts or IC's on the board. You need a support technician for him to have a test inside the equipment. All parts have to be undergo into tester device to determine which is faulty.
thanks.
Feb 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Turns on with Power light then turns off
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Jun 07, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wont stay on
I can help u fix in live chat!
Same TV, same problem. I'll be watching for an answer. The dealer says it is old and outdated and not worth fixing.
Oct 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
