Question about Kodak 8mm Instamatic M80, M85 and M95 Projector Service Manual
Projector won't thread - Kodak 8mm Instamatic M80, M85 and M95 Projector Service Manual
Epson projector bulb won't turn on when rpalced
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Apr 18, 2012 | Epson ELPLP09 Projector Lamp for PowerLite...
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
Hi my infocus projector 4805 glass filter has fallen out, how do i fix it pls (ps i am a technologically incompetent female so need non techy language pls :)
Its commonly refered to as a Light Tunnel Failure. Go to www.avsforum.com and search for "4805 Light Tunnel" and you will finds threads on how to fix the problem.
If you have never opened the PJ before, there are 1-2 threads about opening the cabinet.
I also posted a DIY replacement solution that may help:
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Jan 06, 2011 | InFocus ScreenPlay 4805 Multimedia...
Bell and Howell 16 mm diagram . don't know how to thread the film
Check this Website and see if one of the manuals doesn't give you the answer:
http://www.paulivester.com/films/projector/BH273man.htm
Jul 02, 2017 | Bell & Howell Photography
6 segment color wheel replacement , need a replacement for BENQ mp723 projector.. Got old one out but could use a how to guide for putting projector back together again?????
as for a replacement colorwheel, try http://online.projectordoctor.com/. as for putting it back together, just reverse the order of the dismantle. general rule of thumb: larger thread screws go into plastic, smaller thread screws go into metal.
Dec 09, 2009 | BenQ MP723 Projector
Projector shut off
Your lamp may well have died..
Oct 07, 2009 | ViewSonic PJ402D DLP Projector
How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Feb 23, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Kodak 8mm Instamatic M80, M85 and M95 Projector Service Manual Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
