Question about Braun 8585 Electric Shaver
Power cord is not charging
Whether I plug the cord into the cleaner unit or the shaver, it is not charging
  • Braun Master
  • 1,602 Answers
Most likely, the batteries are dead and need replaced. You need two batteries and they can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
For installation videos, see links below
http://www.youtube.com/watch?v=D6jRpCnB8T4
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Posted on Jan 20, 2014
5 Suggested Answers
  • 10865 Answers
SOURCE: shaver has lost charge, won't recharge on station,
here is the link to the manual and the service center http://www.braun.com/us/home.html
Posted on Jun 23, 2009
brector3
  • 1602 Answers
SOURCE: unable to charge
The cleaning base is the problem. It probably got wet inside and the circuitry is damaged. This is almost always why these go bad. You dont have to replace it to use your shaver as you now know that you can charge the shaver directly from the cord.
If you want the convenience of the cleaning station, you will need to replace it. You can find a new one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-clean-charge-base-p-116.html
Posted on Feb 17, 2010
  • 59 Answers
SOURCE: Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Posted on Apr 21, 2010
brector3
  • 1602 Answers
SOURCE: Shaver won't run without cord
Symptom would suggest batteries need replaced.
You will find compatible batteries at shaveroutlet.com. You will need two. See link below. http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for a helpful disassebly video.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Feb 21, 2011
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
I need to find a Braun shaver center in Seattle wherre I can buy a new power cord for the razor and the cleaner. Is it the same cord for both? Or do I need two different ones?
The same cord can be used to plug into the bottom of the shaver or the cleaning/charging stand. Only one cord is included when the shaver was new.
I can't tell you if you can buy thse items in Seattle, but I can show you where to buy on-line. These items are available at shaveroutlet.com. You will need your model or type number to select the correct cord
Oct 05, 2010 | Health & Beauty
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Hi there, A friend gave me this shaver but there is no charging cord or adapter. I can probably make my own but I need to know if this shave plugs directly into 110-115 AC or whether there is an adapter...
<P>The 8985 shaver only takes about 7&nbsp;volts.&nbsp; The charger that you are missing can be used with 100-240V and has a transformer in&nbsp;the plug&nbsp;that reduces the voltage to just a few volts to charge the shaver.&nbsp; If you connect 100-120V directly into the shaver, you will ruin the shaver.&nbsp; I strongly suggest that you buy the correct cord.&nbsp; You will find it available at shaveroutlet.com.&nbsp; See link below</P><P>&nbsp;</P><P><A href="http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html">http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html</A></P>
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Shaver Stopped. May need power unit series 569 class 2 for series 1 150
By 'power unit', it appears that you are referring to the power/charging cord. If this is the item you require, you will find this item for model 150 (series 1) at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun-charger-cord-for-select-models.html
Mar 19, 2010 | Braun Health & Beauty
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
Braun 8585 Electric Shaver Logo
115 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
