Question about Kenneth Cole KC1296 Watch
Kc1762 Hands time not working
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Can get the time to start
The watch is a chronograph. If the time hands are not working, minutes and hours, you probably need a new battery. If they are working and it is the chronograph(stopwatch) hands you can't get going then you need to push the buttons that control the chronograph.
Oct 16, 2012 | Nixon The 42-20 Chrono Watch All Black One...
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
Analog hands don't move to keep time, all digital functions and displays work.
I think you mean that the hands do not indicate the same time as the digital display. If this is the case,then the hands can be adjusted.
You can get instructions on how to do this from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Mar 01, 2010 | Timex Ironman Triathlon Solar Watch T5G691
How to adjust the time for casio illuminator watch instructions s-1045DV
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Jan 27, 2010 | Casio Illuminator AQ150W1EV Wrist Watch
My husband's watch won't keep time. We have had the battery replaced, so we know it is not that. it worked fine when we first got it. now, after only a few months, the time gets off.
Ther must be some kind of friction/resistance in the final drive ie the hands down to the drive gears. A new battery may temporarily show correct time but will quickly drain under these conditions It may clear over time but if it is new it should be replaced. If you cannot replace it try freeing the hands/gears by manualy turning the hands a few days forward
Aug 03, 2009 | Watches
Kenneth Cole KC1296 Watch Logo
23 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
