Question about Panasonic SCAK410 5-Disc CD Changer
Cant get the cd changer to open
It wont open or switch to aux. It just says error
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
When i change from radio or single disc to the 6 disc changer there is an error it won't read any discs.... It wont even change discs it won't do anything really...
I suspect that your 6 cd changer is having the fault. The error indicates always a system malfunctioning. From our point of view we can probe into for a solution by the following guidelines.
first of all open the 6 Cd changer from the top. look within to find that the changer is jammed inside. If so slowly tapp while you switch on the power. if the jamm clears and the changer ejects, then open out all the cd's present in the changer for any damage due to heat. If this did not solve, clowing chek for foreign particles/dust that has blocked the loading drive.from completing the cycle so as to reset the mode. normally all errors show because of the processor not receiving the complete cycle signals. hence check for all the moving parts, the drives and the loading mechanism. check also for any linkage damge, any leadd specially flexible line wiring to the motors for an open circuit. Slowly turn the motor drive to intiate to confirm if the motor has failed. Altogether use a multimeter and check in all the sections described.
I hope this helps. Good day.
Jun 28, 2010 | Car Audio & Video
I cant get the aux menu on to activate aux
most head units you need an accessory like a disk changer pluged into it to get aux to work.
Dec 05, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Error code "AUX" shows on Kenwood KDC-C667
aux usually refers to auxilary setting not error code
Jul 31, 2009 | Kenwood KDC-C667 6-Disc CD Changer
Chevy Equinox 5 disc cd changer. Car battery died which cycled cd changer several times. Now it just gives cd error message and I cant get the lone cd out and I cannot load a cd.
make sure your alltanator is chargeing from the battery,how you can do that start the car open the hood and take one of the batter cable if the car still run,that means the alltanator is good,if the can turn off when you take the
May 11, 2009 | Car Audio & Video
Fiat punto mp3 or not?
I cant say about the mp3 disk but the aux is auxilary and the leads are located behind the stereo system yellow and red, you can buy the removal pins from most motor factors.
Apr 17, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Auxilary wont work on my alpine cda 9884
you need to go int he teupmode of the radio
turn off the cd changer option and turn on the aux mode
good luck
Jan 19, 2009 | Hifonics Eagle Car Audio Amplifier
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Help pleasee
I"LL SUGGEST U FIRST TRY TO FIX THE AUX INPUTS. CONFIRM WHETHER "AUX IN " IS "ON" or "OFF" .PRESS "SRC" SWITCH UNTIL "AUX 1" or "AUX 2" APPEARS ON DISPLAY. SELECT IT "ON".NOW HOPE FULLY THE CD PLAYER SHOULD PLAY.
May 03, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
Panasonic SCAK410 5-Disc CD Changer Logo
22 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
