Question about GE Energy Star WCVH6260F Front Load Washer
Button's stick or change other settings
When I try to change the temperature of the water or the spin speed the button won't work and when it does it changes a different setting. example: change temperature setting and the spin speed changes instead. The start button has been sticky for a while but usually that is fixed by opening and shutting the door a couple times. With this the other button's I just have to push the one I want changed till it's at the setting I need than I fix the other setting's
    Habit-Forming:
  • 21 Answers
What kind of appliance are you talking about
Posted on Jun 13, 2017
  • 7 Answers
SOURCE: washer not spinning the clothes completely
For the the initial filling of the tub, the pump is not involved. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added. Try removing front (or top) cover and find the water pump. It will have connecting hoses clamped to it. Check the hoses for blockages first. Then check the pump for any objects inside or broken impeller blades. If impeller is broken, replace it only if possible --- if not, you'll need to purchase a new pump. Hope this helped.
Posted on Dec 22, 2007
  • 351 Answers
SOURCE: GE Adora Front Load Washing Machine Problem
Dear Trudz,
all you need to do is clean the filter. you can get to it by unscrewing the front screws at the bottom to remove the bottom panel. Unscrew the filter but be ready to have something to catch the water overflow. Coins did it for us. There was not much lint. Hope this helps.
Cheerup and be happy always
Posted on Apr 10, 2008
SOURCE: fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Posted on Sep 02, 2008
SOURCE: ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Posted on Dec 07, 2008
SOURCE: GE WBVH6240FWW control dial broken-how to remove?
The control knob simply pulls off. I just looked at the other side of one..The knob connects to the main control board. To gain access you must remove the top of the washer. There will be screws at the rear of the machine to remove the top. Once removed, the control panel will be exposed for easy removal. Good Luck, Eric
Posted on Feb 15, 2009
Why does it take two hours to wash a load of clothes
We have a new machine and a couple of the settings take about that length of time. We have a setting that does a wash load in around 30 minutes and tend to use that. It is a lower temperature and a slightly slower spin speed (1100 instead of 1300).
I believe it is because modern machines only have a cold water fill and no hot so the water has to heat up to whatever the setting is.
Try a lower temperature and spin speed, or if your machine has an "eco" setting, give that a go.
Sep 25, 2015 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Fault 9 come on
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
My daughter has moved into a rental house with a very small Whirlpool front loader. There is no model number or manual, and her email is not working. She would like to wash in cold water as is our...
delicate is typically always only cold
the other 2 are usually warm
if you could reach the faucets where the hoses attach to you could turn off the hot water faucet assuring it would only had cold water going into it
Gene
Aug 11, 2011 | Whirlpool LHW0050PQ Front Load Washer
Brand new. Load gets stuck on 14 minutes or some other time & repeats over & over. Wont finish cycle. We have to use the drain & spin to get the water out but then clothes are not rinsed well....
Sounds like you are probably doing a very bulky or real off balance load on a high spin speed setting. The washer is trying to get the load up to spin speed, but the load is too off balanced. Try the lowest spin speed setting for that load. If it makes it through that, then power machine back on and just push the spin speed button until the next higher speed shows up, and then the start button if you want to spin it out better. If it still didn't make it through the original cycle on the lowest spin speed, your load must be way too off balanced, like one coat that is saturated with water. If that is the case, you may even have to squeeze some water out of it by hand before you would be able to get the washer to get it up to spin speed.
Mar 21, 2010 | LG WM2487H Front Load Washer
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
How to select "SPIN ONLY" cycle?
I TOO HAVE BEEN WONDERING HOW TO SPIN ONLY, AND I HAVE THE ANSWER :),, TURN THE POWER BUTTON ON, PUSH THE SPIN SPEED BUTTON NEXT TO DESIRED LEVEL, THEN PRESS START, THERE YOU GO , IT WILL ONLY SPIN, NOT RINSE AND SPIN :), BY THE WAY , I GOT THIS INFO FROM THE ONLINE MANUAL :), SHOULD WORK....
Jan 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
GE Energy Star WCVH6260F Front Load Washer Logo
47 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
