Question about Video Game Consoles & Games
Catwoman code it wont le6t me use my codeand its a new game
I am looking for the code to unlock catwoman on Batman Arhkam City
there area few ways to get catwoman but here's what you need to do.
1. Either buy a new copy of Batman Arkham City for 800 gamerpoints from Xbox Live Marketplace.
2. If you bought the game brand new, you will have a code inside your box. Enter it when prompted at the beginning of the game.
There is no easy way to say this... but you need to by the game new...
Nov 06, 2013 | Video Game Consoles & Games
I need to know the puk codeand pin code for nokia 1280
hi..
You can get the puk code from your service provider itself.. call your customer care and get your puk code and pin code...
Oct 25, 2011 | Nokia 1280 Cell Phone
What is the Restore factory setting security code of nokia 6233
1. If you forgot your master codeand your phone is not currently locked, you will need to reset your phone. Onlya hard reset is necessary in this case. Note that before you reset the phonemake sure you back up all your information, as this reset erases everything onthe phone and makes it brand new. Simply dial: *#7370# It will demand fora security code; put in this code - 12345 , then ok. The phone will restart,while the reset takes place. Once this is done your new security code will be12345 YOU CAN ALSO TRY *#7780# Hope this helped,
Apr 20, 2011 | Nokia 6233 Cellular Phone
When i enter the puk code for my nokia e71-2 it ask for a new pin code but then i get a code error message?
PUK codeand PIN Code: Pleasedont try more than 3 times.If you try more than 3 times the Sim will getlocked.And it will ask for PIN code.Both these PUK and PIN code can be givenonly by the network service provider. Please call the network service providerof your mobile.And ask him to provide the PUK code or PIN code.He will ask yousome basic details like name,date of birth for his verification.And hewill provide you the PUK and PINcode.This is done for free of cost.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 08, 2010 | Nokia E71 Smartphone
2001 DODGE NEON COMP CODE NEED TRANS SENSOR REPLACE IT STILL SAME CODE CAR RUNS PERFECT 3 SPEED AUTO NO OD CANT CLEAR LIGHT CAR WAS IN ACCIDENT WAS HIT NEAR COMP LOOKS LIKE IT TOOK A VERY SMALL INPACT ALL...
If the scanner won't reset the codeand disconnecting the Negative battery terminal doesn't rest the code the computer is damaged and you will need to find another used one that will work in the vehicle or contact the dealer for a new one and get it programmed. Even used these are expensive and hard to find. Having had to replace one myself once I know the cost involved and how difficult it is to find a good used one.
Nov 27, 2010 | Computers & Internet
Replace a serpintine belt on a lincoln mark 7 1997
If your asking how. It's simple make a diagram of the belt routing (there might be a diagram on the frame under the hood). Ther is a tentioner pully that holds the belt tight. Get a ratchet with the proper socket fit it on the nut n the center of the tentioner and you can pull the tendioner pully as to le6t the belt have slack. then carefully take it off of the pully . youll have to twist and wiggle it to come out from behind the fan then install the new one in reverse
Sep 09, 2010 | 1997 Lincoln Mark VIII
Forgot keypad lock code
my mobile n72 ,so my key pad lock code change .but i forgate so,what to do this problem .help me..........
Nov 07, 2008 | Nokia N72 Cellular Phone
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
