Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
Buzzing sound coming from fridge/freezer every 10 minutes lasting around 10 seconds? The water dispenser and ice maker are not hooked up. Fridge and freezer are otherwise working fine. Any ideas? Thanks
  • 451 Answers
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Posted on Jan 01, 2014
4 Suggested Answers
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
mikedurland
  • 481 Answers
SOURCE: kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
I own a Whirlpool model WBM35LW refigerator, a buzzing noise lasts for about 10 seconds followed by a click. I replaced the start relay and overload but the buzzing continues, all seems normal including...
This is usually a sound coming from the ice maker solenoid. It will buzz while it is energized and letting water fill the tray up and then you will usually hear a clicking sound when it is cutoff and the water is stopped. Sometimes if the water line on the back of the unit is not secured properly you will hear various sounds as the water is suddenly stopped and the line moves around, like a garden hose does.
Sep 29, 2009 | Refrigerators
About every 15 to 20 minutes there is a buzzing type sound that lasts between 5 -10 seconds. Then the compressor goes on and refrigerator works fine. Temperature in freezer and refrigerator are correct. It...
Sounds like you have an icemaker that is not connected to water . You need to turn the icemaker off at the icemaker . The buzzing , is the water valve behind refrig , being called for but no water to deliver .
Sep 09, 2009 | GE Refrigerators
Yesterday started hearing a buzzing sound from the fridge. Came home today with a pool of water in the kitchen coming from the fridge. Opened the freezer, ice is melted and inside is relatively warm....
I would check for a bad starter relay first unless you can verify that the sound is comming from the compressor. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 16, 2009 | Frigidaire PLRS267ZAB Side by Side...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Every 3 minutes the fridge makes a loud buzzing sound. seems to come from compressor.lasts about 10 seconds then stops with a click
your start system for the compresser (relay and overload) is out you will need to replace go to www.apdepot.com to look it up by your model number
May 30, 2008 | Maytag Refrigerators
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Dec 05, 2007 | Amana ATB1935HR Top Freezer Refrigerator
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
168 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
