Question about iLive Cell Phones
Ilive manual How do I pair with my nexus7?
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
How to pair my nexus7 with my ipod 4th gen
Via Bluetooth. But why would you want to do that ?
Nov 02, 2014 | Audio Players & Recorders
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
Won't do anything
The internal field effect transistor and diodes have blown. You cannot repair it. Return for an exchange within the warranty period.
Feb 26, 2014 | iLive iSB563B Desktop Wireless Bluetooth...
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
Nexus7 will not connect to the internet after latest update
To update you on my Nexus7 not connecting to the Internet was solved by pressing the button on my router and also pressing the two arrows (that form a circle on my Nexus) at the same time and it connects right away.I hope this helps other people with the same problem.....Colin Bett
Feb 21, 2013 | Asus Systems Asus Nexus 7 Tegra 3...
Just bought ilive Bluetooth speaker. I paired it and it worked once then all of a sudden no music is coming from the speakers just my htc rezound phone. Bluetooth is still connected. Any solutions/
That happens sometimes with BT. Just reconnect. This is annoying, but the phone and/or ILive don't follow up standards that are not in place (yet)
Oct 02, 2012 | Cell Phones
User Manual
here it is for u but i need u to rate me as fixe ya hehe the blue 4 squares!!
http://www.ilive.net/store/p/44-CD-Boom-Box-with-Subwoofer-Dock-for-iPod-.aspx
Aug 17, 2008 | Apple iLive IBCD3816DT Portable 2.1...
Cell Phones Logo
15 people viewed this question
Top iLive Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an iLive Cell Phone Expert? Answer questions, earn points and help others
