Question about Pool & Spa
Reflections Spa will not heat
I have a 2004 Reflections Spa that will not heat when I run the diagonistics test I get the HC code which according to the manual is replace Heater. I've replaced the following and still no heat (Heater, Pressure Switch, Filter,High limit sensor, and Water Tempature Sensor) So now I'm at loss. The Tub works as it should just won't heat (all jets and lights work). The display is flashing and acting like its trying to heat but it doesn't and gets really cold here in the Midwest. Any one with ideas please let me know or a recommended repairman that will service the south suburbs of Chicago. Happy New Year!
    Problem Solver:
  • 9 Answers
Take a Multimeter and measure the voltage at the heater element. If it is getting voltage either 120v or 240v depending on the voltage to the spa, you've got a bad heating element
Posted on Jan 04, 2014
  • 5 Answers
SOURCE: No Heat from Spa
Tcarrigan,
Heater contactors "buzzing": Do you mean normal buzzing or extra loud buzzing? Loud buzzing or chattering can be caused by low voltage to a contactor. If normal sounds, then probably the relays on the contactors is working, but the contacts may be stuck, or burned enough so as not to make contact. First, get a voltmeter and check for 240 volts AC at the heater contactor terminals. If the voltage is low, most likely you need to check the contactors further. Check for dirty contacts, clean if needed. If the contacts are not moving when energized, then you will probably need to replace one or both of the contactors.
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
SOURCE: Heater will only heat spa water to luke warm.
the water in my arctic spa hot tub took 2 weeks to get to 102 should it take that long ?
Posted on May 02, 2009
SOURCE: I have a Purex Triton MiniMax 400 that is cycling
i have the same problem and i jumped the two red wires to bypass the thermal switch
Posted on Apr 09, 2010
thepool
  • 78 Answers
SOURCE: Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
Posted on Apr 23, 2010
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Oct 17, 2017 | 1993 Ford Taurus
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a 2003 cad escalade that is on a lot for consignment. They tell me the battery went dead and that they can't even get it to jump start. I have never had a problem with the battery until now. I...
well the cadillac dealer is right when you pull the battery all codes are gone the best way to handle this is bring a battery down there put it and get your car out of there
Feb 10, 2011 | 2003 Cadillac Escalade
How do i access the front heater core of a 2004 dodge grand caravan , steaming up window and looks like leaking on drivers side
Remove neg batt cable. Drain the cooling system. Remove radiator cap, set heater control to max heat. Drain coolant through valve on bottom rad of the radiator. 12 qt bucket. Pull the carpet out of the way on the driver side floor. Remove the bolts to the steering shaft coupler cover. Remove brake light switch from bracket. Diconnect the power brake booster pushrod. Place towels underneath around area for fluid drippings. Remove retaining clips from HC fittings. Pull the tube out of the HC & carefully rotate them out of the way, plug the open tubes for less mess. Remove the HC bracket bolts, then remove the braket. Push the brake pedal down , the gas pedal up & move the shaft cover out of the way. Pull the HC out of the heat/ac hopusing unit...
Dec 26, 2009 | 2004 Dodge Caravan
1991 Honda Accord LX failed emission test on smog test. High CO and HC on 25mph
not enough info. Typically, CO and HC together can be the result of poor fuel control or misfire, or worn components such as O2 sensor or catalytic converter, but without more data, repair recommendations are likely to waste money and not achieve success.
Mar 07, 2009 | 1991 Honda Accord
Failed Smog Test Close to CA-HC Limits
You can try some over the counter solutions per say. Some of the mechanics in a bottle. They sell some products This will probably be the cheapest router. If this doesn't work then you need repairs.
Pass your emissions test.
Jan 03, 2009 | 1992 Honda Accord
Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Nov 11, 2008 | Sport & Outdoor - Others
Pool & Spa Logo
94 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
