Question about Car Audio & Video
Wire color to radio
I cut the wire on the factory wire harness to trying to install my double din tv in my Monte carlo 2001 ss wanted to know what wire go to what
    Problem Solver:
  • 11 Answers
Light green and dark green -- right front speaker
tan and gray -- left front speaker
light blue and dark blue -- righr rear speaker
yellow and brown -- left rear speaker
orange -- constant power
yellow -- switched power
black w/ white stripe ground
always use a dc electrical test light to be certain your power connections are correct.
Posted on May 21, 2009
Instructions on installing a Panasonic CD player in a 07 pontiac grand prix
Looks like your trying to install a single din size radio in a double din opening. You will need a radio adapter kit that will allow you to complete your installation correctly. Best Buys or Crutchfield would be your best bet for finding the correct kit for your car. They also carry the special connectors that connect to your factory system so no cutting of wires in the factory harness will be nessesary. Hope this helps out.
Dec 20, 2014 | Cars & Trucks
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
I have a 2001 grand jeep grand cherokee can i fit a double din radio in it
no, sorry. Info on aftermarket stuff for your car is here: http://www.modifiedlife.com/2001-jeep-grand-cherokee-car-radio-wiring-diagram/
If there was a double-din adapter, it would be listed with the other dash adapters in the right column below factory the wire colors.
Dec 03, 2010 | Car Audio & Video
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
How hard would it be to put a different cd player in my 2003 Monte Carlo SS ??
It is very simple actually. What you will need is a face plate, an aftermarket wire harness and the skills to connect this wire harness to the new CD player harness, they are usually color coded so very simple. TO remove you stock CD player you will need to pry off the plastic surround then there are 4, 7mm bolts that will need to be taken out and the stock CD player will pull out. Unclip the wire harness and antenna
Apr 01, 2010 | 2003 Chevrolet Monte Carlo
Car won't start after change battery
Your vehicle has 2 ignition wires that you can put back to factory, and start the vehicle.
The wires you are looking to put back together are PINK and DARK GREEN - and found under the D/S dash. (ignition harness - right side of steering column) They will be larger in Diameter than the others.
They were cut to install the security system. They go into the "brain" and out the other side. A relay inside the BRAIN is most likely failing.
If you no longer want the alarm installed, simply match up all of the factory colors. Use crimp-on but t-connectors for secure connection.
Let me know if you need more help.
Jan 14, 2009 | 2001 Chevrolet Monte Carlo
Wiring diagram
Do you have any connectors left intact? All you should need is the alternator power, grd, starter, distributor power, advance
Jul 23, 2008 | 1986 Chevrolet Monte Carlo
Car Radio Problem
It is your amplifier.You can buy a $12.00 ,Amp Bypass Turobowire Harness.{12 VOLT-TRAVEL,
Jun 10, 2008 | 2001 Chevrolet Monte Carlo
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
