Question about Electrical Supplies
Devilbiss powerback gt5000
Not to familiar with generators... starts fine and delivers voltage, but is constantly "surging" as the governor adjusts the rpm... is this normal?
    Sergeant:
  • 402 Answers
No this is caused by a dirty fuel jet and tube which is normally located underneath the fuel solenoid on carburetor
Posted on Jan 04, 2014
3 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: I own a powerback gt5000 electric generator. It
The best place to obtain manuals at a discount price is -
repairmanual.com
Posted on May 09, 2009
centurion_BB
  • 83 Answers
SOURCE: Operation of a Devilbiss GT5000 generator
not to familiar with the generators however , I do know that the old style receptacle for 240 volts was three prong. Then OSHA got a hold of it and added a second ground to make it 4 prong, Thats why some houses use a 3 prong dryer cord and some use a 4 prong. hope this helps. and if it has 2 240v outputs BONUS they dont make em like they used to.
Posted on Aug 13, 2009
Testimonial: "Thank you for the answer. Electrical stuff is my weak link. If you need to know anything about investing in the markets I'll return the favor."
My kohler 12res starts but governor moves constantly which makes my voltage erratic
this is a common complaint to these , what it boils down to is allways a fuel problem , if its gasolene then its in the carb if it's nat gas then it's in the regulator/vaporizer
you'll have to clean these items to see if that helps . someof those liguid cleaners sometimes works but i find a good dissassembly cleaning to be the best
Jan 28, 2015 | Kohler 12 kW Emergency Power System -...
I have an 8.5 onan diesel generator that idles fine but surges badly when the air conditioner is started - the motor races out of control - what could be wrong?
Is it only when a load is on the unit? I am assuming the voltage output os correct and the HVAC is working properly on shore power and does not have a locked compressor. If it does there is too much demand on the generator and it cannot govern, if the HVAC and ouplut voltages are all good, make sure you have the right weight oil and level in. It sounds like a governor issue, or the engine is mechanically not provifing enough HP. More than likely a governor issue
Aug 29, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
Hello, my Briggs & Stratton generator, PP5000, Intec, 8 hp, Model 202412, type 0167E1, has lower power output, 180 Volts in stead of 220-230 Volts. Any idea where I should look ? Engine is 8 years...
Hi and welcome to FixYa. I am Kelly
Usually when you have a lower voltage output that is yet above 150 VAC the problem is as simple as the engine is no longer running at full speed. This could be caused by binding carb or governor linkages but more often than not the Governor adjustment screw has backed off over time causing the engine to gradually slow so the output voltage drops. The user does not notice it so much until the output drops more than 15% and you notice dim lights... slower running equipment etc.
Look for a circular plate / governor speed plate near the base of the governor lever but off to one side that has a spring that attaches to the governor lower end of the governor. There should be a screw with a locking nut. Loosen the nut and turn the adjusting screw clockwise to increase engine speed. (You may have to barely loosen the pivot nut on the governor speed control adjustment plate to make the speed adjustment.... tighten when done with speed adjusment) Watch your output voltage and adjust the voltage to 225 VAC with NO LOAD. The voltage will drop as loads are added. Make sure to tighten the lock nut on the adjusting screw or in a matter of an hour you will have low voltage again from engine speed dropping. What ever you do.... DO NOT adjust the governor arm base attach point where it attaches to the engine.
Just so you know a weakened governor spring can cause the speed drop also. If the speed keeps dropping with extended use, you may have to change the spring that goes from the lower end of the governor arm to the governor speed adjustment plate.
Thanks for choosing FixYa,
Kelly
Apr 20, 2011 | Briggs & Stratton 3,250 Watt 6.5 Hp...
I have a 7000 watts devilbiss gas generator. My question is: are the RPM's of the engine adjust to the load automaticly Thank you Walter
hi Walter
find the lever from the governor ..The lever has many holes.Make sure the lever is securely attached to the shaft where it exits the crankcase.On most air cooled engines,maximum speed is usually around 3500 rpm.If the governor is not working properly,engine over speed could damage the engine.Yes adjust the load automaticly. regards savumihai71
Dec 16, 2009 | Electrical Supplies
Aug 13, 2009 | Electrical Supplies
Ginne stalls under load
Likely that your governor has creeped out of tolerance. Very common with Emerald line of generators. Try to borrow, if not already have one, a multimeter that is able to read frequency and voltage. At no load, frequency should be 62 or 63 hertz. At full load, frequency is going to be around 57-58 hertz. Voltage at no load should be 127 or so, full load should drop down to around 115 give or take. Adjust governor for faster engine operation for low voltage / frequency, slow down for too fast frequency or high voltage (though that is likely not the case here).
Problem with Emeralds is that the governor spring rubs on bracket, and also has a tendency to stretch. If this is the case, adjusting governor will be near impossible between full and no load.
Jun 10, 2009 | Watts Onan Portable Generator - 4000 ,...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
repairmanual.com
Apr 20, 2009 | Electrical Supplies
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Electrical Supplies Logo
155 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
