Question about GE PSS26PSS Stainless Steel Side by Side Refrigerator
I have a GE Profile refrigerator model PSS26PSSSS that is having issues keeping the freezer cool. The unit is almost three years old and has worked fine up until a few weeks ago. We started noticing that there was little ice or what ice was there was frozen as one block. There was also water that had "leaked/dripped" from the ice machine to the food below and froze. If I set the temperature control for the freezer to say 0, -1 it will not stick. It will only get as cold at about 3 degrees. The refrigerator side works fine, any ideas?
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
Posted on May 20, 2009
The excessive moisture is a possible reason. I am not going to say the only reason. The thing is your freezer is trying to defrost more moisture now because of the extra flood of water until we get that under control we will just need to try a few things. With doing this we may be able to get the temps down more. I have plans for the next steps. Your refrigerator has a memory control board and I just want to see how its reacting to changes.
Nov 19, 2012 | GE Profile Stainless Bottom-Freezer...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | GE Profile PSW26P Stainless Steel Side by...
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
heatman101
Dec 04, 2010 | Pds GE Profile Bottom-Freezer Drawer...
Nov 17, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 01, 2011 | GE PSS26PSS Stainless Steel Side by Side...
Aug 27, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Aug 15, 2009 | GE PSS26PSS Stainless Steel Side by Side...
221 people viewed this question
Ok, I can try that. Do you have any thoughts though on the fact that the temperature will not stay below 0? Thanks.
