Question about Canon BJC 80 InkJet Printer
Ink carriage won't release to the print position
5 Suggested Answers
SOURCE: canon mp730 ink cartridge carriage will not slide
I have the same problem. Anyone have any suggestions on what to do about it?
Posted on Jan 14, 2010
xptareq2000
  • 1447 Answers
SOURCE: Will not print. power light flashes green and
It goes to damage Ink absorber .Many ink absorb this pad.You must be reset it self or any workshop.if itself
1.Press power button and resume button realize resume button and press 3 time then go to power button.
Posted on Feb 12, 2010
MacD7
  • 67 Answers
SOURCE: MP610 won't print
Turn off and unplug from the wall for 60 seconds. Make a visual inspection to see if anything is blocking carriage movement. Plug back into wall and switch printer back on. Give it a few moments to reset itself. If successful, you should be able to change cartridges normally. If not, you may have caused gears to jump out of timing. Try this process at least 3 times before you give up.
Posted on Apr 26, 2010
  • 144 Answers
SOURCE: my canonmp480 printer will not position carriage properly to accept new ink cartridge
Try to open front cover of the printer and hold a STOP button for about 10 seconds.
Posted on Jul 05, 2012
Trying to bring ink holder in position to insert ink
Turn off printer, release carriage lock. Or turn on printer and unplug power while carriage moving, then move carriage to replacement position.
Jan 01, 2010 | Epson Stylus NX400 InkJet Printer
I have an epson stylus PHOTO RX500. I need to change the "black" ink cartridge but the ink carriage will not move into a position that will allow the top of the ink carriage to be lifted. When I push the...
Try unplugging the unit and then plugging it back in. When you first power it up, it should do an initial system check, which involves moving the print head. Unplug the unit the moment the print head is in a position to change the cartridge. I did this with my old Canon when I had the same problem and it worked. Hope it works for you too.
Feb 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Wont print
try try again..........
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Jan 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print quality
CHECK INK LEVELS RUN DIAGS AND IF YOU NEED A NEW PRINTHEAD TRY THIS;
I had this problem;
TO RUN SELF TEST
My printer wony printer after replacing both ink cartridges
I had this problem;
THIS WORKED FOR ME
TO RUN SELF TEST
Jan 01, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
I need to know how to get the defective printhead out.....
I had this problem;
THIS WORKED FOR ME
TO RUN SELF TEST
Dec 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
KODAK 5300 WILL NOT PRINT
I had this problem;
TO RUN SELF TEST
Kodak easyshare 5300 printer
I had this problem;
TO RUN SELF TEST
Dec 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Won't print although it goes through the motions of printing. I have changed the ink and cleaned the printheads
I had this problem;
TO RUN SELF TEST
Canon BJC 80 InkJet Printer Logo
16 people viewed this question
old marine
old marine
