Question about Samsung DLP HL-P5663W 56" TV
Weres the dlp chip on your toshiba - Samsung DLP HL-P5663W 56" TV
Dlp chip after replacing
you will need to pull the chip out & clean out the dust & other foreign particles that were allowed to fall in & lightly brush off the chip (with a very soft brush, again to remove dust & foreign particles.
Apr 28, 2015 | Mitsubishi Tv Dlp Lamp 915p061010 For...
What is going on my toshiba dlp projector image is with lot of sand grains
Sounds like either a bad DLP chip, or dirty optics. If the "sand grains" seem to "multiply< then you DO have a bad dlp chip, some mirrors are "sticking".
Apr 26, 2014 | Toshiba Televison & Video
How to fix my 65" toshiba white pixel problem
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
Apr 06, 2013 | Toshiba 65HM167 65" Projection Television
White dots appear across the screen
if you have a samsung, mitsubishi, toshiba etc DLP the white dots are caused by stuck mirrors on the dlp chip. so the dlp chip will need replacement
Apr 04, 2013 | Televison & Video
Toshiba 62HM195 DLP right hand screen black but left hand screen works
You are describing a damaged optical light engine or the display chip which is part of it (chip is about 200 plus a lot of labor)
Apr 01, 2012 | Toshiba 62HM195 62 in. HDTV DLP TV
White spots
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Jan 24, 2012 | Mitsubishi WD-65C9 65" DLP HDTV
How to install toshiba dlp light chip
This is a part of folk lore, the DLP display "chip" is not available from the company who made this (or for that matter any other brand) and even if it was you would need the $1,000 plus desoldering station to attempt its replacement.
What is your problem? dots? if that is it the answer is either buy a optical light engine or buy a new set.
Nov 26, 2011 | Toshiba 65HM167 65" Projection Television
I have the Toshiba 65hm167 DLP, It has a bunch of white spots on the screen and they increase in number daily. I have read of this problem on other T.V.'s but not this one. I have also read several...
Yes,this problems is the Light projection Engine.The chip is bad.This happen to many models of tvs in the industries.Sony,Samsung,Mishibishi and Toshiba they all use the same IC chip.Call Toshiba make kind of deal with them,help u replaced the chip or the Light Engine it self.This problems is not new many people went to You Tube **** about this problems.
Sep 03, 2010 | Toshiba 65HM167 65" Projection Television
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
