My Ac/dc adaptor for my R/C boat is making this buzzing or humming sound when i plac it in the socket, it make the sound before i attach the battery pacj for charging and after attaching the pack the
Company name is Huazheng Electronic, model is CH-4116D input is ac 220-240v 50/60hz.
I have exactly the same adapter and it literally burnt out and I mean burnt out. Luckily I was at home but if I hadn't been god knows what would have happened. I have seen a German site which states that this adapter should have been withdrawn...but admittedly this was the 2 pin version.. I seriously think you should watch yours very very carefully.
Posted on Sep 22, 2017
  • Geoff Bury
    Geoff Bury Sep 22, 2017
    I forgot to add that I was using it to charge a R/C Boat as wrll
  • Geoff Bury
    I forgot to add. I was charging up my son's remote controlled boat which I am guessing is the same as yours
    Champion:
  • 232 Answers
If it is charging properly I would not worry about it. Chargers are a device that ALWAYS make noises, there just often out of our range. If it is making a VERY loud noise, then I would suggest locating a replacement power supply.
Posted on Jan 05, 2014
4 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
Posted on May 26, 2008
Jubert
  • 249 Answers
SOURCE: AC Adaptor problems
Update your bios.
Posted on May 25, 2009
cheap to fix
  • 404 Answers
SOURCE: Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Posted on Aug 01, 2009
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
Feb 23, 2015 | Samsung Computers & Internet
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
My computer a 1905-s301 will not run on just ac power
It means either the AC adaptor has failed or the DC socket on the laptop is broken. Check the AC Adaptor's output DC voltage using a multimeter first.
Dec 18, 2013 | Toshiba Computers & Internet
Plug in ac adaptor to Dell inspiron 600m and does
Sounds like you have a broken DC Power jack. This is where the small socket where you attach the AC adaptor breaks loose from the motherboard , resulting in the laptop not charging properly or at all . If you have to wiggle the power jack to get a connection then this is definately theproblem.
Most computer reapir shops can do this for about $100. Or if your handy with a soldering iron and dont mind disassembling the laptop , you can always buy a new DC jack for your make and model off ebay and try to solder it yourself!
If you found this post helpful , please rate my post
Regards
1234s282
Apr 17, 2010 | Dell Inspiron™ 600M PC Notebook
This camcorder was gifted to me recently and comes with an inbuilt battery. however i dont knw much about camcorders. i dont have a charger for this and dont know where is the socket for charging on the...
Yes it is the dc socket that you will use to charge your battery . It charges right on the camcorder itself with your ac adaptor . make sure the camcorder is in off postion for it to charge.
Larry
Jul 10, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
Hum from dell laptop power adaptor when using a sound system
as i understand you are facing this hum on all the three AC adapters,
there could be any of the following reasons for that
1) If the laptops were bought within the same period and all the AC adapters came from the same faulty lot
2) Or the AC adapters are made in this way so they produce this hum always
Try calling their Tech support helpline for Dell and see if a replacement can help you or if the AC adapters have a design fault of producing hum is their a solution that they have for it
If you Think my solution was of any help please do rate me
May 17, 2009 | Dell - PS-5201-7D (PS52017D) Power Supply
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
