Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Starter often just clicks wont turn over every time
Have gone through several new batteries thinking that was the problem, however when I turn the key on the riding mower 50% of the time it just clicks. If I keep trying it will eventually turn over and start. Very weird. The plugs are good, oil filter new, oil is new. Dont' know where to go from here...
I had a similiar problem. Finally it would not start at all. I replaced the solenoid switch and problem solved.
Posted on Jun 01, 2009
  • 2,005 Answers
Check and, or; replace your battery cables
Posted on May 20, 2009
No Click to turn the engine
sounds like cellinoid is bad or the starter drive is not engaging could need new starter
Oct 21, 2017 | 1999 Chevrolet S-10 Pickup
I think my starter has gone bad
i would guess,you either have a poor connection to your battery or a flat battery. test your battery before checking the starter. ok?
Apr 15, 2013 | 1994 Chrysler LHS
Wont start
the clicking noise is usually 2 things, step on try jump starting car and if starts have battery tested as it is probably bad (free testing at most chain auto stores), the other usual problem is that the starter has gone bad, when whoever tried turning off car while driving might have put into start mode and burnt out the starter when it engaged at high speed.
Jun 09, 2012 | 1998 Ford Taurus
78 ford f150 I turn the key, i here the solenoid click and all power in truck is killed. i could wait a few minutes and disconnecdt the negative battery cable and the power would be back. After several...
Are you sure your battery is good and able to take and keep a full charge? The only thing in the start circuit that could cause a big drain on the battery is a shorted starter. But if you can send power and it cranks okay, I don't think you have a bad starter.
Is the ignition key on when you crank it and have no spark? Does your distributor rotor turn when the engine is cranking?
I would try a new solenoid. If it clicks it should send power on to the starter on the big cable. Make sure all battery and ground connections are clean and tight. If still a problem, buy a voltmeter and learn how to do voltage drop tests. This will help find bad connections.
Sep 13, 2017 | Ford F-150 Cars & Trucks
My dodge aries wont start every time. I turn the key several times and it makes a clicking sound before it tries to turn over and ever when the engine catches it wont start completely. I changed the...
The clicking is the starter solenoid which is normal, the starter motor is not making a good contact due to it's worn, a starter replacement will fix the problem.
Jun 30, 2010 | 1987 Dodge Aries
2003 325i started to turn over slowly today, and now it does not
sounds like it might be a bad connection on the starter try jumping the starter and see if it turns over
Apr 15, 2010 | 2003 BMW 325
Starter relay clicks when you turn ignition key on
no this is either caused by a defective starter solenoid (on starter) or a defective positive battery (red) cable, both are common on this year of explorer.
Jun 21, 2009 | 1991 Ford Explorer
My 1998 jetta has a new starter but it won't start
check to make sure battery in good conditions.the battery voltage should be 12.5.if all is good.problem is in starter solenoid.if it wont replace with the new starter.also bad battery cables.replace battery cables if they havent been changed.a bad transmission range switch.
Jun 07, 2009 | 1998 Volkswagen Jetta
Car wont start...sometimes
Sounds like a bad starter solenoid, usually cheapest and easiest to replace the starter and solenoid as a unit. It is always best to check for power between the solenoid and the starter with a test light, if the solenoid clicks but the test light doesn't light up you have found the problem in the solenoid.
Apr 28, 2009 | 2003 Pontiac Grand Am
1989 Toyota Camery Wont Turn Over
If you can turn the engine by hand, your starter has gone bad. Cables get hot because energy normally used to turn starter cannot and has to go somewhere! If you can't turn by hand, it's possible engine is seized.
Mar 23, 2009 | 1989 Toyota Camry
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
273 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
